Make your own it will be way cheaper unless you paln on going to a boneyard but
then you will be in the same predictament eventually!!
for the pins and connectors
http://www.sherco-auto.com/cg.htm
For bad @$$ marine grade last forever wire
http://www.skycraftsurplus.com/index...TS&Category=24
Using shrink wrap and split loom and grouping the circuits together in a say all right
side wires together left side etc. basically to make it easier to work on and better
looking can make for a better harness.
Putting new pin terminals in the computer connector and either new connectors
completely or using the stock with new terminals will beat a junk yard harness.
If you use that gold contact protector when you do this will make for a corrosion
free and lasting harness better then the $500.00 harness brand new!! Whatever
harness you go with using it will keep the connectors like new and the deoxit
cleaner will clean the ones you reuse and for maintenence. I use the crap out of
that stuff and would reccomend it to anyone who demands performance out of
everything that is electric it really does make for better conduct and the pen one
lasts a long time and can be used about anywhere.
http://store.caig.com/s.nl;jsessioni...2&category=292
