type of oil to use in a 6.0 - Ford Truck Enthusiasts Forums
Old 03-05-2008, 06:21 PM
bigbubba87's Avatar
bigbubba87 bigbubba87 is offline
bigbubba87 is starting off with a positive reputation.
What kind and weight of oil is recomended in a 2003 6.0. what do ya'll use? We run rotella 15-40 in our other diesels would it be alright to run that in the 6.0 too? Thanks Justin
Old 03-05-2008, 06:33 PM
OZX1's Avatar
OZX1 OZX1 is offline
OZX1 is gaining momentum as a positive member of FTE.OZX1 is gaining momentum as a positive member of FTE.
Quote:
That's what I run in the summer, rotella synth 5/40 in winter... May go to synth year-round.
Old 03-05-2008, 06:45 PM
IB Tim's Avatar
IB Tim IB Tim is online now
Site Administrator
IB Tim has a superb reputationIB Tim has a superb reputationIB Tim has a superb reputationIB Tim has a superb reputationIB Tim has a superb reputationIB Tim has a superb reputationIB Tim has a superb reputationIB Tim has a superb reputationIB Tim has a superb reputationIB Tim has a superb reputationIB Tim has a superb reputation
Slippery...
Old 03-05-2008, 07:39 PM
utahtom's Avatar
utahtom utahtom is offline
utahtom has a good reputation on FTE.utahtom has a good reputation on FTE.
Since you asked... There is a boat load of them (pun intended).
Conventional Lubricants:
Motorcraft Super Duty 15W-40 or 10W-30
Penzoil Long-Life 10W-30, 15W40
Shell Rotella-T 15W-40
Chevron Delo 400 15W-40, 10W-30
Mobil Delvac 1300 Super 15W-40
Valvoline/Cummins Premium Blue 15W-40
Union 76 Guardol QLT 15W-40
Union 76 T5X Heavy Duty 15W-40
Kendall Super-D 3 15W-40, 10W-30
Quaker State FCI HDX Plus 15W-40
Exxon XD-3 Extra 15W-40
Phillips 66 Super HD II 15W-40
Conoco HD Fleet Supreme 15W-40, 10W-30
Citgo Mystik Premium Fleet 15W-40
Citgo Mystik JT-8 15W-40, 15W-50, 10W-30
Castrol GTX Diesel 15W-40
Synthetics:
Amsoil 15W-40 Synthetic Blend Oil
Chevron Delo 400 Synthetic 0W-30 or 5W-40
Mobil 1 Turbo Diesel Truck Oil 5W-40 Synthetic
Mobil Delvac 1 ESP 5W-40 Synthetic
Motorcraft Super Duty 5W-40 Synthetic
Valvoline Premium Blue Extreme 5W-40 Synthetic
Shell Rotella T 5W-40
Schaeffer's Supreme 7000 Synthetic Blend 15W-40
Schaeffer's Supreme 9000 Synthetic 5W-40
Kendall SHP Diesel (synthetic blend) 15W-40
Petro-Canada Duron XL 15W-40 Synthetic Blend
Royal Purple Synthetic 15W-40
Citgo Mystik SX-8 15W-40 Synthetic Blend
Advantage Duragard Super HD 15W-40
Ford is recommending to use the following oils for the listed operating temperature:
SAE 15W-40 is the preferred oil above 30 degrees, but it is acceptable for use down to 10 degrees, and is recommended for towing down to this temperature.
SAE 10W-30 is the preferred weight between -10 to 30 degrees.
SAE 5W-30 and 5W-40 is acceptable for use below 30 degrees, and 0W-30 is acceptable below zero.
(All temperatures are in Fahrenheit)
Most (not all) of the above info is from BITOG which is an excellent source of oil info
FWIW Many 6.0 owners run 5W-40 synthetic year round with great results-
Old 03-05-2008, 07:48 PM
barnbridge's Avatar
barnbridge barnbridge is offline
barnbridge is gaining momentum as a positive member of FTE.
I've done UOA (used oil analysis) on my 6.0 for almost 4 years now. I've used Rotella 15w-40, Rotella 5w-40 and Mobil 1 5w-40. The Mobil gave me the best results, less shear being the most noticable quality. Downside to the Mobil- price, $22 per gallon.
Old 03-05-2008, 08:16 PM
69cj's Avatar
69cj 69cj is offline
69cj has a brilliant future69cj has a brilliant future69cj has a brilliant future69cj has a brilliant future69cj has a brilliant future69cj has a brilliant future69cj has a brilliant future69cj has a brilliant future69cj has a brilliant future69cj has a brilliant future69cj has a brilliant future
No Offense---
Old 03-05-2008, 08:40 PM
cartmanea cartmanea is offline
cartmanea is a name known to allcartmanea is a name known to allcartmanea is a name known to allcartmanea is a name known to allcartmanea is a name known to allcartmanea is a name known to all
I'm going Rotella Syn 5w40 on my next change. Maybe if I want to spend the extra money I'll eventually go Mobile. My dad has the same engine and we've discussed buying Mobile by the 55 gallon drum, but he does a lot of heavy towing so I think he should stick with a 15w-40. Maybe I'll still buy a drum though, 55 gallons is only 15 oil changes
Old 03-05-2008, 09:12 PM
BobsF350's Avatar
BobsF350 BobsF350 is offline
BobsF350 is starting off with a positive reputation.
ive been running rottela 15w-40 in the late spring threw the late fall.And run rottela 5w-40 syn from the late fall to late spring.I will be looking into staying with a syn oil threw out the year.Starting this year.iam thinking about royal purple or Lucas oil.
But rottela 15w-40 and 5w-40 syn has been good to me for almost 5 years and over 100,000 miles
Old 03-05-2008, 09:24 PM
I want to find an oil and stick to it since I've heard switching back and forth is not good. So I guess I'll stick with synthetic 5w-40 year round. I don't do much towing anyway.
Old 03-05-2008, 10:01 PM
ingman ingman is offline
ingman is starting off with a positive reputation.
Delo 400, year around. I ran it in my 97 stroker to.
Hay utahtom, where are you in northern Utah? Im in Brigham City?
Old 03-05-2008, 10:25 PM
tippmann87's Avatar
tippmann87 tippmann87 is offline
tippmann87 is starting off with a positive reputation.
Does anyone recommend the 15w-40 Mobil Million Mile Oil?
Old 03-05-2008, 11:19 PM
mnmwhit's Avatar
mnmwhit mnmwhit is offline
mnmwhit is gaining momentum as a positive member of FTE.
I use Mobil-1 year round
Quote:
Old 03-05-2008, 11:23 PM
tippmann87's Avatar
Quote:
yea, i've been using it since i got my truck.........just seeing what others think
Old 03-05-2008, 11:28 PM
bigbubba87's Avatar
will it hurt it to run rotella 15-40 year round in it
Old 03-05-2008, 11:36 PM
tippmann87's Avatar
it won't hurt, but if it's really cold where you live, many ppl will recommend 5-40
What oil to use? Ono6.0 6.7L Power Stroke Diesel 11 10-27-2016 02:37 AM
Best 6.0 Oil?? SNIPER168308 6.0L Power Stroke Diesel 86 04-13-2016 02:53 PM
Used truck with 6.0 "needs oil pump"...? 12valveEx 6.0L Power Stroke Diesel 2 08-05-2015 02:23 PM
Rotella oil not certified by Ford for 6.0?? Catfish_Man 6.0L Power Stroke Diesel 83 11-08-2006 06:48 PM
anti foaming oil for 2004 6.0 diesel redfir 6.0L Power Stroke Diesel 3 01-21-2004 09:36 AM
Tags
10w30, 15w40, 3006, 400, 60, chevron, cummins, delo, ford, oil, purple, royal, schaeffers, type, weight
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
