Go Back   Ford Truck Enthusiasts Forums > Performance, Engines and Troubleshooting > Computer Chips and Tuners
Register - Join us, its Free! FAQ Members List Timeslips Calendar Mark Forums Read
Is F-150 Still King?
LinkBack Thread Tools
  #1 (permalink)
Old 03-05-2008, 04:05 PM
F-SUPER DUTY is starting off with a positive reputation.
SCT XCalibrator 2
Does anyone know if this will work on 99 5.4 F250?I just want to be able to adjust timing & fuel a little.
Sponsored Links
To remove this ad, register today!
  #2 (permalink)
Old 03-06-2008, 07:05 AM
tex25025's Avatar
tex25025 has a good reputation on FTE.tex25025 has a good reputation on FTE.
It's possible, it lists f150 then it says 1996-2007 f250-f550, and right below that it lists 7.3/6.0 diesel, so taking all that it looks like it should. However, that's if I'm reading their application list correctly.
__________________
'06 6.0L Turbo Diesel King Ranch DRW 4.30 Gears
Spartan Stage 1 Towing Injectors
Spartan 64mm Non-VGT Turbo
Fluidampner
Headstuds
Beta Spartan Phalanx
Fuel Regulated Return
FASS 150/180
5" Straight-Piped MBRP Exhaust
Tranny, EGT, Boost, and Fuel PSI C2 Gauges
Water Temp, Oil PSI, Volts Antique Beige Gauges
  #3 (permalink)
Old 03-06-2008, 09:10 AM
fordmdb's Avatar
FTE Sponsor
fordmdb is starting off with a positive reputation.
F-SUPER DUTY it should work fine. One thing i would do is make sure your X2 is updated with latest firmware and tune revisions. This can be done via www.sctflash.com... and go to Tech Support area
__________________
www.5startuning.com
mike@5startuning.com
SCT Custom Tuning Dealer / Level 4 Engine Controls
Come Visit the South Carolina Chapter here!
2005 V10 F250 CC , 2005 F150 Std. Cab , 2006 Ford 500 , 2002 GT Stang
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is On
Trackbacks are On
Pingbacks are On
Refbacks are On
Powered by: vBulletin | Copyright ©2000 - 2008, Jelsoft Enterprises Ltd.
Ford-Trucks.com and Internet Brands, Inc. are not affiliated with the Ford Motor Company.
