I am changing to a 12 volt system on my flatheat 239 engine for a 1948 f6 .I have seem many difrent precasted brackets for the alternator. I was wondering if any one has used one and can recommend where to get one that will work.also i looking for a one wire altenator any recomendation. thanks for the help
They aren't cast, they are fab'd out of two steel plates. I got mine off eBay from Certified Electric. I am beginning to believe a brace back to the intake manifold from the rear of the alternator would be a good idea. Certified sells a turnkey mount/alternator too.
Look@ this item-#140213213645-on Ebay right now.Yours for only $119.00-OUCH!you can also make your own for about 20.00.Do a search of the archives.Steve.
Flatheads are completely different, and while you can make your own, the slingshot for mounting the alternator is usually only about $35. I wouldn't even consider making my own for that much. It need to fit the front of the intake tightly.
I changed my '50 over useing a bracket like the one Abuq f1 used. It cost me 65.00 at little dearborn in St. Paul Mn. It worked good I used a 3 wire GM altenator with a harness from Summit that has a Diode in it to keep the current from running backwards. The harness was 18.00
