Changing timing chain 1997 4.6l. Any cues?
Hello all.
I live in the Dominican Republic and good mechanics are a rare occurence, usually the guy who owns the shop is good but his employees are breaking more stuff than they fix.
I and some mechanics that I trust identified the loud clacking and pinging noise I have as being the timing chain. It basically sounds like a diesel engine.
I ordered the complete kit for my truck, two chains, two cam sprocket, a dual crank sprocket, hydraulic tensionners, guides, etc. It came in a kit. I also purchased the gasket kit to finish the job.
My question is: Can I do this myself? I understand about mechanics and I do most of the time the troubleshooting by myself, I also do more than minors mechanical jobs, mostly brakes, suspension, steering and electronics myself. I have plenty of tools.
Do I need special tools? Pullers for the gears? Clearance guages? Is it something that you remove and put back easily? Is the procedure for properly install the gears to have correct timing complicated? Are the marks easy to spot?
Basically I need to know if there's anything that could give me a bad surprise, an innaccesible nut that needs a special tool or a retainer that needs voodoo praying to put back in place.
It seems to me like a straight forward job, remove the front end of the engine, maybe even the radiator I don't know. I'm not scared of this but I want to make sure about the tools.
If anybody has cues, please show yourself. I'm trying to avoid mechanics, not for the cost, but for the future problems.
They will probably do the timing chain job ok, but they're the kind that are liable to forget to tighten the bolts on the radiator fan so it'll fly through the radiator 3 weeks later
(it really happened on my wife's Grand Cherokee after they changed the water pump)
Get a comprehensive repair manual like the dealers use. They get them from Helm Inc. in Highland Park, MI. That's a city within the city of detroit. The firsttime we did it it was a prototype engine with no instructions. Just take your time and locate every bolt. It is a lot more to tackle than a push rod motor. One of the tricky parts is getting the hydraulic chain tensioners to go back in since it has a ratchet to over come. Don't worry about them when you put them back on since oil pressure will adjust them. Mark all gears and chains with reference marks like paint. They don't take kindly to being hit with a stamp. I believe you may have to loosen the front pan bolts so the cover goes back on without leaking. It's been 20 years since we did this but if a couple of mechanics like us can do it without instructions you should be able to do it.
Eaulive,
Did you ever get around to tacking this yourself and, if so, how did it turn out during and in the end??? Did you have to take the engine out of the truck to do this?
I am facing the same prospects on my '99 Expedition 5.4L 2WD at the moment but I have no way to take the engine out. I am told it can be done with it left in, but, not sure just what I am going to be in for.
I hope you get an email that I posted this! :-)
Thanks,
Mark
Thanks,
Mark
The most important tool would be the cam holder, it's a tool that will keep the cams from moving while the gears and chains are off. Ford says "engine damage WILL occur" if it is not used as the 4.6 is an interferance engine. Do you have a Factory service manual? I strongly recommend that you have one before you start, check out the eBay stores. Chilton and Haynes will only provide enough information to get you in serious trouble.
Anyways, the last time I ran the engine (just to pull it down off the ramps) after bolting the oil pan back to the block after dropping it enough to squeeze my arm in to discover and remove right chain guide pieces (!), it was clear that now the timing seemed off. This was not the case when I ran the engine to pull it up on to the ramps. Collapsing oil pressure was my symptom. Sure enough, a large chunk of plastic right chain guide had lodged in the oil take up screen/opening. So, I figured, at least oil pressure problem was solved. But, I had done nothing else at that point except bolt the oil pan back on and fill it with oil and started it up to drive off the ramps. so, no timing shake before dropping the oil pan but a noticeable vibration the first start up after putting oil back in. One guy suggested that when I started it back up after putting the oil back in that the timing chain may have slipped a link or two.
So, where is a good place to get the cam holding tool (besides a dealer parts shop)? And, if the chain has slipped, is it going to be hard to re-time it? I have heard the chain kits are color coded. is that enough for me to get it straight again or am I going to need bigger guns? if the timing had not appeared to have become an issue, i suspect i could have just locked the cams as they were and replaced the chain and guides. but, not sure now. what direction would such a slippage move? and, could I tell somehow which link was the original correct positioning with respect to the cams?
It was also mentioned on another forum's post about this that I would most likely break a bolt getting the cam covers off since my 1999 2WD 5.4L expedition xlt has 170000 miles, so the cam cover bolts have been set and baked for a long time.
Note: I am fairly mechanically inclined but not a mechanic (by trade or by hobby even) but a guy with your typical home garage and tools. I have replaced a starter, alternator, a/c compressor myself. But, is this a job I can even do or am I going to really need mechanic/shop tools and know-how? If it is too big a job, what amount of time/cost should I expect if I towed it to a shop? It is 11 yrs old with 170000 miles. Is it even worth taking to a shop??? A friend I asked about it pointed out that there may be more gone wrong and damaged than just the timing chain guide; this could become more expensive than the truck's worth.
FYI and thanks!
Update
Did you get this job done? When I did my heads on my 97 4.6L I basically had to touch everything you'll have to and there are 2 special tools that they recommend, one holds that cam shaft and the other is used to turn the shaft. I live in Canada and to buy both from a jobber was going to cost $200.00 plus, so my buddy and I made them (he has a welder so it was pretty easy). I did mine with the engine in place, it's not a quick job and involved lots of beer.
Bill
Bill
macubus
2004 - 2008 F150
08-03-2019 01:03 PM
dionysius
11-22-2016 01:30 PM
