more hp and torque
Theoretical Exercise Only, OK...?
I've often wondered what would happen if you cross referenced some engine parts catalogs and threw a set of competion/HD rods & pistons, a little milling hear & there, Meebey' offset grinding the crank, relocating the pins higher for just a tad more stroke?
Bigger valves & a full on portjob with multi angle valve job? Custom cam, of course.
And if you wanted to go further:
Sheetmetal intake or extrude-hone the factory piece. Adapt a bigger T-Body, Bigger injectors?
Of course I've always thought these engines just scream for someone to put a turbo on.
Justa' a thought...
Justa' a thought...
I gotta 94 with 46,000 miles and got the 2-into-1 intake boot from a V-8 truck, and added a piece of pipe and a clamp on filter in place of the stock box. I also removed the smog pump, the second cat, and poked out the first one and run a single inlet, dual outlet flowmaster (pretty quiet) and noticed a decent improvement, but nothing to make it any more "thrilling".....And the mileage seemed to improve, to boot.
I think next I'm gonna smooth out the butterflies and shaft in the throttle body and add a spacer.
And there is a lengthy, detailed thread in the supercharger/turbocharger/nitrious section of FTE where a guy built a turbocharged 300. It's a good read even if one isn't going to copy the concept.
Originally Posted by frederic
I like exercises.
To me the 300 behaves much like a big block - large bores, heavy rods, decent stroke as starting material. Just two less cylinders.
I know the big six is not rev-happy, but I've often wondered how it would respond to a good blue-print & some quality light weight/HD internals. Add a few more traditional Hotrodding techniques & it should be surprising.
I'll have to look up that thread.
crestfallinman
16
03-10-2008 08:55 PM
