03-07-2008, 07:38 PM
This what I was able to decode from a 65 Econoline Shop manual.
E14 - Regular Van
T - 170 CID motor
H - Lorain assembly plant
416126 - Is the build sequence and it seems it was built before August of 1964. So the van is most likely a 1964 van being the serial number is from before the 65 model year.
090 - 90 inch wheelbase
M - Color White
E143 - Regular series Van
A89 - Standard Van
A - C4 Automatic Transmission
01 - 3.50 Gear ratio
The other line is 3600 Gross vehicle weight
85 Horse power at Specified RPM
The remaining numbers are unclear. The 84 may mean the van was Home Office Reserve. Someone else maybe able to confirm this.
So I would say your van is a 1964 Van built around Dec Jan.
If the heater system is locate on the floor and not on the cowl. It is safe to say it is a 64.
As for being a travel wagon, It should have windows, The numbers given say standard van which would be like a closed in van with some to no windows.
By the way welcome to FTE. There is quite a few of us early econo guys here. I have 3 of the trucks, but nothing done to them as of yet.
__________________
64 Econoline Truck.
67 Econoline truck
85 F150 Explorer XL
86 F150 Exploere XLT Ext cab
66 Merc 1Ton Flat deck
78 F250
