Buildup!! 06 crown vic front suspension into 67 F100
#1458
Wheel Vintiques
theWheelsmith.net Home for Custom Wheels and Accessories
You can send Wheelsmith all your specs & they build the wheel you want as I understand it. They have a page on their site showing what specs they need.
#1459
#1460
Brackets
Brackets and front cups came from ThorBros and I got the gussets for the four link from AVS. The front bags with the cup is located right where the spring should sit.
#1464
i was lucky with my last engine swap. i was able to find a driveline at the local recycle yard. it came off a 70's 3/4 ton 4x4 long bed..
get your measurements, at the center point of the u-joints. take that and a measuring stick or tape. i like the folding measuring stick, as i can use it without the hassle of the tape flipping over and falling or breaking just as i have it in position...
#1467
#1468
This is off the subject but did you have to modify the cab at all when you used the front end of the crown vic? I mean in regards to the engine/trans you used. I am planning on using the front end, engine and trans out of a 04ish crown vic. Any input would be greatly appreciated!
#1470
I have just done most of this swap. I have a link to videos and everything showing how much room you have. It is in my own thread.
To make the CV crossmember work is mostly just cutting the front crossmember out, and working it all in. I took about 100 photos of the swap thus far. Some with numbers to make it easy for the next person. I swapped in the 4.6 and trans, but those require cutting out the next crossmember too. Once that is out, I used the CV trans crossmember cut down to fit the truck. You need to do nothing to the cab though. Other than cut a hole in your firewall if you want the computer inside. I did.
Is the OP exceeding bandwidth or something? Images don't work any longer.
