Go Back   Ford Truck Enthusiasts Forums > Older, Classic and Antique Trucks > 1967 - 1972 F-100 And Larger F-Series Trucks
New! Use your Facebook, Google, AIM & Yahoo accounts to securely log into this site, click logo to login
1967 - 1972 F-100 And Larger F-Series Trucks Discuss the Bumpsides Ford Truck SPONSORED BY:
Is F-150 Still King?
  #121 (permalink)
Old 03-28-2008, 03:55 PM
carcrafter22's Avatar
carcrafter22 carcrafter22 is offline
carcrafter22 is gaining momentum as a positive member of FTE. carcrafter22 is gaining momentum as a positive member of FTE.
I would but if I made my own tank it would only be from aluminum and I dont have a tig welder to weld it all up properly. I like the idea of using a stock tank anyway. I could then use the sending units from them and wire a switch in that switches the gauge over depending on what tank you are using at the time.
__________________
67 F100 sc/sb 07 crown vic front suspension, 94 lincoln mark 8 IRS limited slip 3.27 gears, isuzu 3.9L diesel, T56 6spd trans. Lowered 5" rolling on 18" goodyear tires 225/60/18, 4wheel disc brakes. Twin turbos HY35 & HX52, Sheied diesel built injection pump. And I'm only getting started.
Getting 32.4 MPG on regular diesel so far.
  #122 (permalink)
Old 03-28-2008, 04:32 PM
65fordman125 65fordman125 is offline
65fordman125 is starting off with a positive reputation.
you will be in luck on the picts as it goes my girlfrend LOVES to take pictures i guess this time that will work well. i shure hope you are right about the ebay deal for the calipers becauce i stoped at the carquest today and they told me 87 bucks a peice but then it clicked them i dont have a core at 57 bucks so that was about a 350 or so for that hole set up.
  #123 (permalink)
Old 03-28-2008, 05:24 PM
http://cgi.ebay.com/ebaymotors/ws/eB....cWAT.m240.lVI
Here is the ebay auction. I know it has ended but I emailed the guy a week or so ago and he said he would still sell them at that price.
__________________
  #124 (permalink)
Old 03-30-2008, 09:39 PM
Smile
before the project
dimond plate door panels
got the motor and tranny out getting ready
That is what i am starting with under the hood got lots of room for improvement good news to me i cant make it any worse
thats the 351W that is going in looks lots better
Cant leave out daddy little helper
I know i always like to see picts of projects so i thouhg you guys might like to see what im working with ill put more when i get the CV frontend and get the show on the road should only be another 5-7 days now.
  #125 (permalink)
Old 03-31-2008, 01:03 AM
I cant see the pics for some reason, all I am seeing is little red x's.
I have a small update for the project. I just got home this weekend and went straight to work on the rear supension. I needed to lower the rear 3" so I removed the front spring hanger and cut some of the top section off (a little less than half of the overall height) and raised the whole shackle up 2.5" then welded it back to the frame. I did this to both sides and then remeasured the with the bed back on. I noticed raising the forward leaf spring shackle the 2.5" lowered the truck exactly 1.5". I will be extending the rear shackle making it longer by 3" and hopefully that will get the truck lowered by a full 2.5"-3". This only took me about 40 minutes to do everything and I am hoping to only spend about an hour on the shackles tomorrow. I will post pics up of it all tomorrow when I am finished.
This is a great way to lower the truck a few inches with just a little of your time and the best part is that it is free instead of a couple hundred $$ for a kit.
__________________
  #126 (permalink)
Old 03-31-2008, 03:33 AM
hope they worked this time
  #127 (permalink)
Old 03-31-2008, 07:01 PM
72-F100-4V 72-F100-4V is offline
72-F100-4V is starting off with a positive reputation.
Well im picking up my 2007 Marquis front end tomorrow. It was a little steep at 600, in north jersey, but its got 7 thousand miles and comes with all of the hardware and brackets and the steering coupler.
I did notice that a Lincoln Town car at the yard had the same suspension as the Marquis. So there are 4 cars these front ends can come out of, Marauder, Vics, Marquis, Town cars.
I am also looking for a rear end from a T-Bird, Cougar, or Mark now. It would be cheaper to go that route instead of rebuilding the 9 inch with a sway bar, and disk brakes plus I would gain the smoothness of an independent rear.
BTW, pics to come tomorrow when I get the front end.
Does anyone know if braided front brake lines are made for the Marauder??? I will need a set soon for my front end.
__________________
72 F100, shorty, W/2004 32valve Mach 1 motor, 5 spd.
2006 ZX14, thats faster than your truck everyday of the week! 184.2 MPH at The Maxton Mile.
  #128 (permalink)
Old 03-31-2008, 10:18 PM
thunder31634 thunder31634 is offline
thunder31634 is starting off with a positive reputation.
If you have a big bearing 9 inch, you can get the backing plates and calipers off of an 8.8 rear-end off an explorer. They will bolt right up.
  #129 (permalink)
Old 04-01-2008, 01:18 AM
microb microb is offline
microb is starting off with a positive reputation.
$600 still isn't bad, especially with those miles. Good to know that the town car front is the same. Same measurements too? That makes finding parts alot easier. I can't wait to get this going on my truck. I know it's been asked before on this thread, but does anyone have a driving truck with this ifs mod and/or mark viii, cougar, etc irs? I'm sure I'm not the only one who is anxious to hear how it rides. I'm having recurring dreams of riding in an F-100 that feels like a crown vic/ town car and I check this post every day for new info/pics. Also is anyone using irs from a mark viii? I've seen pics of the rear stance with this irs, but I'm curious how it will match up with the ride height of the crown vic type ifs. Can't wait to hear more from you all and good luck.
Mike
  #130 (permalink)
Old 04-01-2008, 11:49 AM
Woodyp's Avatar
Woodyp Woodyp is offline
Woodyp is starting off with a positive reputation.
For anyone in the KC area that may be interested , I saw 3 Mark VIII's at 2 different self serve junk yards this weekend. One was at the pick-n-pull on Truman road at I-435 and two were at U Pick It on Indenpendence Ave. at I-435. the two at u pick it were non-posi. I asked about the price and they said around $100. I didn't check out the one at Pick-A-Part but I did see the complete rearend was under it. 2002 was the newest crown vic I saw at either yard.
  #131 (permalink)
Old 04-02-2008, 12:17 AM
UPDATE: sorry no pics today I need to get another memory card. I bought another rearend yesterday along with hydraulic brake booster.The new rear has 31 spline axles and traction loc with 3.27 gears and 11" disc brakes. woohoo!! The hydraulic brake booster is much more compact than a vaccum brake booster. I am makeing a braket that will make the hydro booster a boltin setup. I cant wait to finish it but I need to get small piece of steel plate in the morning to finish it up. The neat thing is that I only have about 20 minutes in the hydroboost setup so its an easy install.
__________________
  #132 (permalink)
Old 04-02-2008, 09:44 AM
That is cool, I got the hydro booster with the 32 Valve motor I bought. So to see how you will do it first will be great. It looks like it will fit right where my manual brake master cylinder is at, just needs new holes.
How do you plan on routing the hoses? I have a feeling that all of the hoses that I got with it, might not reach. I was thinking about using high pressure braided hose from summit with some AN fittings.
Did you get the brackets made for the trailing arm? Got any good pics of it installed? And did you rotate the mount to get it mounted at a level angle?
__________________
  #133 (permalink)
Old 04-02-2008, 12:55 PM
spitfyre spitfyre is offline
spitfyre is starting off with a positive reputation.
just a note for anyone looking to use mark/bird/cougar irs, the markviiis have aluminum control arms as well as the pumpkin, if you wanna use coils just get some for a bird/coug along with 4 of the factory isolators to use on the top and bottom of the springs, when you put the coils in the airbag pockets just position them so that they are both aligned, when me and my dad did the coils on his mark we just put the springs so the end of the coil on the bottom was towards the inside of the car, inline with the centerline. sorry to jack, but this is an awesome thread!
  #134 (permalink)
Old 04-02-2008, 07:58 PM
Ok I finally have some update photos for you savages....
Here is the hydroboost installed, I made a bracket that stuck 2" away from the firewall and uses the factory 2 bolt holes to mate up to the 4 studs on the hydroboost I plan on making a diamond plate cover for the bracket later on.
Here is the engine with the much bigger turbo installed. There is only about 3/4" between the turbo housing and the hydroboost but I think it will be ok.
__________________
  #135 (permalink)
Old 04-02-2008, 08:02 PM
I painted everything with the hoses and filters on because I am replacing them all later on anyway so they will be all black.
I also have thought of taking my hydroboost bracket to a machinist I know to have a solid block of aluminum carved out just like it. I havent decided yet but for now I can mock everything up and its a good thing too since it is a close fit between the turbo and hydroboost
__________________
Tags
03 , 06 , cradle , crown , f100 , ford , front , hood , shaker , slammed , suspension , swap , upgrade , vic , victoria
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is On
Trackbacks are On
Pingbacks are On
Refbacks are On
Guidelines - Contact Us - Ford Truck Enthusiasts - Archive - Top
Powered by: vBulletin | Copyright ©2000 - 2009, Jelsoft Enterprises Ltd.
