Buildup!! 06 crown vic front suspension into 67 F100
#1142
well I was wanting to do this build on my 92 ranger, till I measured my track width today... 57" and the CV has a 63.4"... I don't think it'll fit...
unless I had a new xmember custom fabbed and even still there's steering arms to shorten and all sorts of work...
#1143
Well, I made it to the junkyard today. There was no less than 7 CV's & GM's! All of them had the front suspension complete with the exception of the rack units. One car had the engine out already, so that will be the first one pulled. Wednesdays and Sundays are "half price days" so they will cost us less than $100 each. Plus, the owner said he would make us a deal since we are planning to pull 3 suspensions. 1 will be for my `58 stepside, 1 will be for my buddy's `59 Chevy (which also has a 34" frame width), and 1 for his `40 Packard (Which can be narrowed to 34" in the appropriate section). We will probably head there Sunday and pull all 3 since we now have a list of needed tools........
#1144
The reason I bring up the whole variable speed business is I put a 2005 GM front end on mine and the variable pump is there. You can leave the pump's wires not connected to anything and the system will work fine but you will have to set the amount of assist manually and leave it. I was able to get a 2008 rack though and I will not have to deal with this problem.
Hope this helps.
SS
#1145
sorry i havnt addid any pics of my build, ive got a cap on my internet cause i gota run off a card, but heres an update lemme know what yall think its a lil dark my camra sucks
Got the whole front end done boxed everything forward of the cab, bedliner on the frame and semigloss on the firewall, motor and trans are in, gota finish up the tranny crossmember so i can get the pinion angle right to drop in the 8.8 this weekend, then the long job of wiring and running brake lines....
SS
#1146
#1147
SS
#1151
#1152
im not to sure what my vacume booster is from i think its an 80s dodge, but i was lucky enuf that the master cyclender from a 93 CV fit right on it, i had already had that booster on with my old setup and im running the 93 MC instead of the 03+ cause ive decited to not use the ABS and the proportioning valve is threaded into it and its easier to plum with the linelock
as for fuel im running a BBK inline fuel pump from summit and am about to start plumming the metal lines, there is a high pressure fitting that requires a certain expensive tool but my parts guy is gona hook me up to borrow that.
i still havnt started on the wiring yet but yes im planning on running everything from the 03 CV computer and all, i tossed around the idea of using a megasquirt setup but then id have to get a tranny controller too so im just gona strip up the harness take out what i dont need and run the stock ECU with a dyno tune to remove all the EGR and O2s and stuff
#1154
hopefully everything will work fine with the P/S rack i do plan on mounting that module inside behind the dash so technicaly everything should work at is would on the crown vic.
Ill be working on the wiiring i think for the next few weeks, stripping out all the airbag and impact sensor wires, power window and lock wires, ABS stuff, alot of the emissions stuff cause it will all get deleted in the ECU, Ill probably integrate in a painless kit i have for all the lights, guages, wipers and such, jump the inertia switch wires, splice a new plug into the start switch, fuel pump and fan , im sure theres more im forgeting but itll all get there eventually, and i gota figure out were im going to mount the fuse panel.
#1155
SS
