Buildup!! 06 crown vic front suspension into 67 F100 - Page 104 - Ford Truck Enthusiasts Forums
  #1546
Old 12-07-2014, 10:58 PM
Jrothman Jrothman is offline
Jrothman is starting off with a positive reputation.
Crown vic swap
Can't see the pics for this swap. Any ideas why?
  #1547
Old 12-08-2014, 01:17 AM
elgemcdlf's Avatar
elgemcdlf elgemcdlf is offline
elgemcdlf is gaining momentum as a positive member of FTE.
Quote:
This is an old and for the most part dead thread. I don't know what you want pics of but the CV swap is common place now. The IRS is also becoming quite popular. His diesel, I haven't seen the 4BT in other builds but larger diesels in larger size (250 & 350) trucks while not that common are out there.
A search on any of these topics will yield info and pics other than this thread. Here is one with the CV up front and the IRS out back. http://www.fordification.com/forum/v...p?f=22&t=54398
Yes a shameless plug for my truck.
  #1548
Old 02-02-2015, 02:03 AM
Wink-FX4 Wink-FX4 is offline
Wink-FX4 is starting off with a positive reputation.
Check Coker Tire for their HotRod Steel Wheels, many different sizes 15-20 and all still take the 8 1/4 inch inner diameter hubcaps.
  #1549
Old 08-27-2015, 10:06 AM
Todd TCE's Avatar
Todd TCE Todd TCE is online now
SPONSOR
Todd TCE is gaining momentum as a positive member of FTE.
And I'd like to also give it a bump with regard to the new TCE big brake kit options for the CV front end. Building upon our Marauder kits over the years we've revised this kit now to include 15" rotors paired with the Wilwood Aero6 front caliper. A sweet and simple package fairly priced for your custom build needs!
__________________
TCE
Your one stop....For Wilwood Brakes!
  #1550
Old 08-27-2015, 03:20 PM
f100today's Avatar
f100today f100today is offline
f100today has a good reputation on FTE.f100today has a good reputation on FTE.
Quote:
Nice brake kit. Looks like the marauder kits need wheel spacers. Does the cv kit? If so, that will probably be a problem on a f100 swap. The track width of the cv is much wider than the original F100 so that already limits how low you can go and usually necessitates custom wheels. $2200 = ouch to most of the people who do this budget based cv swap. Good luck.
  #1551
Old 08-27-2015, 03:31 PM
Todd TCE's Avatar
SPONSOR
Quote:
Thanks. Good catch; clearly we've packaged this as inboard as possible for maximum wheel clearance, but yes wheel fit will be based on the wheels design for sure. Deep dish wide lips are out. A good brake friendly spoke is needed.
The standard Marauder 13 and 14" kits will also work but have narrower 1.10" rotors. Also they will need a smaller 1" bore mc due to the piston sizing. Those use the narrowest of options the FNSL6 caliper.
For now the CV conversion was being thought more to be the 15" market.
For the money....it is well priced really. Perhaps a few hundred more that similar Wilwoood 15" factory kits is all.
Thanks for looking.
  #1552
Old 01-07-2016, 09:19 AM
Toakley123 Toakley123 is offline
Toakley123 is starting off with a positive reputation.
Sounds like you got everything going as planned for yourself, good job man. I was wondering if you were going to leave the rear end stock or are you going to add a crown vic rear end? I'm asking because I plan on doing the crown vic front suspension as well but want to do the rear as well while not giving up my 9" rear end.
  #1553
Old 01-07-2016, 09:35 AM
f100today's Avatar
Quote:
Hate to tell ya, but this dude hasn't been on in nearly two years. I doubt you will get a response.
  #1554
Old 03-23-2017, 08:40 AM
tamlee272 tamlee272 is offline
tamlee272 is starting off with a positive reputation.
1964 ford f100
i finally have my truck and have been trying to decide between the crown vic ifs and mustang II. I know the vic is an easier swap, but the real question. I know a lot of people go ahead and use the 4.6 engine. I have a 4.9 straight I have built and want to use can you do this swap without cutting out the cross member or will the 4.9 sit in the cradle without a lot of mods
  #1555
Old 03-23-2017, 10:33 AM
UNTAMND's Avatar
UNTAMND UNTAMND is offline
UNTAMND has a great reputation on FTE.UNTAMND has a great reputation on FTE.UNTAMND has a great reputation on FTE.UNTAMND has a great reputation on FTE.UNTAMND has a great reputation on FTE.
Quote:
The engine difference is minor. It's not like it's that much larger.
There will be a lot of fabricating no matter which front end you use. You could brace the original frame mounts and then remove the bare minimum to get the cv front end in, then brace the factory mounts back down to the cv front end. Or measure and build new up to where the old mounts are... Lots of ways to do the same thing, but it relies on your fab skills.
Is there a reason you're keeping the inline? Seems like adding a nice suspension but keeping a low performance engine isn't what most people do. Is your goal to lower the truck, or just better handling?
You may also want to start a new thread if this gets very involved. This original thread has been inactive up until a little while ago. Lots of great info if you take the time to scan through all the pages.
  #1556
Old 03-23-2017, 10:36 AM
Salty Dog's Avatar
Salty Dog Salty Dog is offline
Salty Dog has a great reputation on FTE.Salty Dog has a great reputation on FTE.Salty Dog has a great reputation on FTE.Salty Dog has a great reputation on FTE.
Welcome to FTE.
Id start my own thread to give it a fresh start. But either way, you'll get alot of help here.
Justin
Almost Bought the Farm scatgo Offroad & 4x4 134 02-11-2011 10:47 PM
My Fuggy Project suzuki1750 Offroad & 4x4 110 07-24-2009 12:00 PM
stacks installed! c00nhunterjoe 1994.5 - 1997 7.3L Power Stroke Diesel 45 07-18-2008 09:44 PM
Torque Specs for You! tjbeggs 1994.5 - 1997 7.3L Power Stroke Diesel 9 02-19-2008 05:09 PM
my expy's new little sister amm888 New Member Introductions 1 12-17-2006 09:11 PM
Tags
03, 06, cradle, crown, f100, ford, front, hood, shaker, slammed, suspension, swap, upgrade, vic, victoria
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
