Go Back   Ford Truck Enthusiasts Forums > Regional Chapters > Southern Region > Louisiana Chapter
Sign in using an external account
Register Forgot Password?
Register - Join us, its Free! Albums FAQ Members Tech Guides Search Today's Posts Mark Forums Read VendorsUsed CarsGarage
Welcome to Ford Truck Enthusiasts Forums
Louisiana Chapter Join Chapter, Leader: Tangi Cowboy
  #1 (permalink)
Old 03-04-2008, 11:14 PM
62 blue 62 blue is offline
Garage is empty, add now
62 blue is starting off with a positive reputation.
Smile 1962 223 distrbuter instal
I pulled the distruber out and dont have a clue how to instal.any tip would be appreciated.I was told that i should have marked it after i pulled it out.I just got the info after the fact.
  #2 (permalink)
Old 03-05-2008, 07:04 AM
rbloodhound's Avatar
rbloodhound rbloodhound is offline
Oilfield Class
rbloodhound has much to be proud ofrbloodhound has much to be proud ofrbloodhound has much to be proud ofrbloodhound has much to be proud ofrbloodhound has much to be proud ofrbloodhound has much to be proud ofrbloodhound has much to be proud ofrbloodhound has much to be proud ofrbloodhound has much to be proud of
I am not sure on something that old. I have no experience on point type dist.
Just guessing Get the #1 cyl to Top dead center. Install the dist to where it is pointing @ # 1 cylinder on the rotary cap. You can then crank it and adjust the timing either by ear or with a timing light.
Their should be timing marks on the harmonic balancer.
__________________
Robert
Join the Louisiana Chapter, Click Here
13 Explorer XLT Ecoboost
09 F350 SRW, LWB, 4x4 6.4 Lariat
79 Bronco 460, auto, 39.5 TSL
LIFE TIME MEMBER OF NRA
  #3 (permalink)
Old 03-05-2008, 09:40 AM
walrus's Avatar
walrus walrus is offline
walrus is gaining momentum as a positive member of FTE.walrus is gaining momentum as a positive member of FTE.
I think Robert is right. Just make sure it's TDC on compression stroke (not exhaust), with both valves closed.
__________________
Mark
2006 F250 SD CC FX4 Lariat 6.0 PSD
2001 F150 CC 5.4L
"Proudly clinging to my Guns and Religion."
  #4 (permalink)
Old 03-05-2008, 12:15 PM
Thanks.I should have marked it before i pulled it.
  #5 (permalink)
Old 03-05-2008, 02:25 PM
Oilfield Class
No problem. We are glad to help.
How about joining the LA chapter. Just click on this link.
JOIN THE LOUISIANA CHAPTER, CLICK HERE
__________________
Robert
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Forum Jump
Powered by vBulletin® Version 3.7.5
Copyright ©2000 - 2013, Jelsoft Enterprises Ltd.
SEO by vBSEO 3.5.2 ©2010, Crawlability, Inc.
vbulletin Admin Backup
