Go Back   Ford Truck Enthusiasts Forums > Performance, Engines and Troubleshooting > Performance and General Engine Building
Register - Join us, its Free! FAQ Members List Timeslips Calendar Mark Forums Read
Is F-150 Still King?
LinkBack Thread Tools
  #1 (permalink)
Old 03-04-2008, 11:46 PM
classic4x4 is starting off with a positive reputation.
Question Header Troubles....HELP
I have a '77 F-150 4x4 Custom that has a 1975 360 in it. The stock exhaust manifolds on it are junk, and I'm trying to find a set of headers that will fit. I've been having trouble because no one can match a 360 in the year '77.
Was there a chassis change from 1976 to 1977? For Jegs that's the cut off, they sell headers for a 360 in a 1976 F150, and the guy on the tech line told me that they wouldn't fit my 1977. Any body have any ideas?
So I'm really curious if I should buy headers for the motor year and CI, or for the body year. I'm leaning towards the engine year and CI because that seems a little more logical, I just wanted some reinforcement on my brain storming.
Thanks guys!
Sponsored Links
To remove this ad, register today!
  #2 (permalink)
Old 03-05-2008, 09:14 AM
Conanski's Avatar
Conanski has a good reputation on FTE.Conanski has a good reputation on FTE.Conanski has a good reputation on FTE.
Was the same series engine available after '76? How much did the truck change from '76 to '77? If the FE series wasn't offered after '76 then you could have a big problem, you'll definitely need the headers that match the motor, but it's anybody's guess if they'll fit on the truck.
__________________
Paul O
1990 F150 4x4 XLT X-Cab 5.0, 3.55, Comp 35-349-8, Flowtech LT's to 3" single, FRPP Mass Air Conversion
Under construction: '85 351HO, Dart Iron Eagles, Roller Rockers, Typhoon intake, Crane 444232, 24lb Injectors, TweecerRT, Innovate LC-1 wideband O2
1990 Ranger 2wd, 2.3 Briggs & Stratten, 5-speed, 3.08 gears, sliding rear window.
  #3 (permalink)
Old 03-05-2008, 10:05 PM
turret_plug is starting off with a positive reputation.
SHORTIES................. In my recent experience with a 4x4, they worked perfectly because the Y pipes were there, and I just ordered them for the year of the engine and not the truck itself, worked out fine.... I had to use my ford precision alignment tool (hammer) to "adjust" the passenger side header a bit, but all in all, It worked out fine, I wish I had some photos, but I sold the truck.
__________________
1980 F-100 Stepside... 302, Edelbrock performer series Carb, Intake and Cam...Flowtech headers, and Flowtech dual turbo mufflers
2008 PT Cruiser, stock...... for the time being!!!
  #4 (permalink)
Old 03-15-2008, 06:04 AM
chrono4's Avatar
chrono4 is a name known to allchrono4 is a name known to allchrono4 is a name known to allchrono4 is a name known to allchrono4 is a name known to allchrono4 is a name known to all
I'm pretty sure there wasn't a frame change between the years, as motor towers, cabs, and just about everything interchange. Ford just quit offering the FE series, and changed the grill around.
__________________
--Andrew--
Rocking a 79' f150 with a 300 and a 4 speed........
Full York OBA Install
Welding a 9"
Very simple front bumper
Lowering Spring Towers
Hi, I'm Andrew and I have a wheelin problem that is often disrupted by fabbin and drinkin, glad to meet yall.
Technical Advisor
  #5 (permalink)
Old 03-15-2008, 06:34 AM
2020 is starting off with a positive reputation.
It should be good with the 76 headers.The trucks didn't change that much if any underneath to 77-79.Engine mount towers are the major changes probably because the FE went away and the 351-400M took it's place.
__________________
95 Lightning
93 Lightning
twice as fun
  #6 (permalink)
Old 03-15-2008, 06:43 AM
chrono4's Avatar
Yeah, the towers changed, but the mounts never did.
__________________
--Andrew--
Welding a 9"
Technical Advisor
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is On
Trackbacks are On
Pingbacks are On
Refbacks are On
Powered by: vBulletin | Copyright ©2000 - 2008, Jelsoft Enterprises Ltd.
Ford-Trucks.com and Internet Brands, Inc. are not affiliated with the Ford Motor Company.
