351C Building - Ford Truck Enthusiasts Forums
351C Building
Old 01-18-2002, 05:27 PM
Nitro Nitro is offline
Nitro is starting off with a positive reputation.
351C Building
I have the chance to buy a 351C out of a Torino and I picked out a whole list of what Im going to put into it. I planned this engine not to be a dog at all. I want this to be pretty snappy. Here is what I put in it:
Summit Rebuild Kit 10.22:1 CR
Crane PowerMax Cam and Lifters (Cant find the specs but it had about a .530 lift)
Manley Stainless Intake and Exhaust Valves
Comp Cams Springs
Summit Oil Pump (High Volume)
Summit Timing Chain (True Roller)
Weiand X-CELerator intake manifold
Edelbrock 750 CFM
Heddman Headers
With all of this stuff and some good ARP fasteners for the engine and a little chrome my bill came out to $1963.39. Not too bad, I least I didnt think it was. This engine will probly see 6000 a few times in its life cuz I love to street race and go to the drags. Can anyone tell me if this thing will be snappy enough or should I get some more goodies??
Thanks
Nitro
Old 01-19-2002, 02:26 PM
Bill_Beyer's Avatar
Bill_Beyer Bill_Beyer is offline
Bill_Beyer is starting off with a positive reputation.
351C Building
Is this a 2V or 4V 351C? I'd be interested to know if you're able to locate Manley SS valves for a 2V.
Old 01-20-2002, 01:18 AM
mustange70's Avatar
mustange70 mustange70 is offline
mustange70 has a good reputation on FTE.mustange70 has a good reputation on FTE.
351C Building
I am in the process of building the same motor with the same things (ro similar things) and I would like to contact you and ask you for some detailed info from your rebuild. But one question can be answered right now. How much power is that going to make and what heads do you have?
82' Flareside with 400 horse under the hood
Old 01-20-2002, 10:54 AM
351C Building
This engine is a 351C 2V and you can get Manley Stainless Valves for them in Jegs or Summit I found them in both. These may be for the 4V but the 2V heads can be machined to accept them so Im using them. This engine isnt built yet, In fact its still sitting in the Torino. But I still dont know what kind of power this thing is gonna make. Anyone got any ideas?? Oh yea and Mustang70 my email is bcd_bcd(No Email Addresses In Posts!) if you wanna contact me.
Nitro
Old 01-23-2002, 11:02 AM
xyfalcon500 xyfalcon500 is offline
xyfalcon500 is starting off with a positive reputation.
351C Building
well, your setup is nigh on identical to mine, except that i have still got stock 302 open chamber heads with 2V valves. Mine puts out about 300-320 hp. Have you got a manual or auto transmission? if it's an auto, you really should get a high-stall torque convertor.
Old 01-23-2002, 11:48 AM
bubbaf250's Avatar
bubbaf250 bubbaf250 is offline
bubbaf250 is starting off with a positive reputation.
351C Building
[updated:LAST EDITED ON 23-Jan-02 AT 12:50 PM (EST)]Nitro,
351C 2V engines were factory rated at 163-177hp (using SAE net "real" numbers) with 9.3-9.45:1 compression, stock exhaust systems, and stock Autolite 2100 2V carbs.
I'd concur with xyfalcon500 and guess that you should get close to 300hp with all the mods you're listing, especially the higher compression, camshaft, 4V carb, and headers.
Old 01-24-2002, 07:46 PM
351C Building
yeah... about the factory output numbers... ford australia quoted 240-260 flywheel horsepower for the 351 2v 2bbl released here (from 1970-78 or so, spanning a few models), but it only actually made about 205 flywheel horsepower, tested with the stock motor out of the car on an engine dyno. Why the discrepency is so large is hard to explain, other than a marketing tool used by Ford.
Old 01-24-2002, 07:49 PM
351C Building
sorry, that's 351 open chamber 2v heads, NOT 302...
Old 02-18-2002, 03:29 AM
335clevo 335clevo is offline
335clevo is starting off with a positive reputation.
351C Building
With the Ausie clevos the 302, (2v) had between 200 and 250 hp, depending on year of manufacture. The 2v 351 had 230-250hp, depending on maunufacture, the 4v (GT) Clevo had 300hp and the 4v (GTHO) clevo had 380hp. Ford Australia actually said the gtho's had 300 hp for insurance reasons, but with its roller rockers, extractors, 11 to 1 compression and 780cfm Holley it dyno tested 380hp. The XAGTHO (which never actually reached full swing production before being killed off) alegedly had 410hp. This is rediculious in my opinion, stick to 300 hp or so and your engine will last longer.
335c
Old 02-18-2002, 11:09 PM
351C Building
And.., as i was saying, the 251C 2v never had anywhere near that output; rather it was more like 200-205hp at the flywheel. The GT's 300 is realistic, though.
Old 02-23-2002, 03:49 AM
351C Building
>flywheel.
OK, I'm not trying to start an argument but the figures I had on the 2V hp came from a manual I have for the XA, XB and XC Falcons. It states that the 2V 351 Cleveland engine from the XA and XB's had 250 hp @ 4600rpm. The 2V 351 Cleveland fitted to the XC has 217 hp @ 4500 RPM by the manual. The 4V clevelands are rated a 300 hp @5400 rpm. Just for interest the XA and XB 302 had 230 hp @ 5000 and the XC 302 had 202 hp @ 4600. The vehicle manual is "Max Ellery'sd Vehicle Repai Manuals, FALCON/FAIRLANE, 1972 - 1979, XA, XB, XC" And the Hp ratings are on page 87.
I have heard that the XYGHTO (4V) dyno tested 380 -385 hp.
335C
Old 02-24-2002, 06:29 PM
351C Building
The numbers that your manual quotes are the factory hp ratings, and in that respect they are accurate. but subsequent engine dyno testing has proved the 351C 2v to only put out about 205 hp in bog stock form.
Old 02-24-2002, 10:39 PM
351C Building
Thanks for clearing that up,
But weren't the XC's detuned (lower compression)? Wouldn't thast mean the'd have even less power again?
335C
Old 02-25-2002, 11:33 PM
351C Building
quite probably... although remember that the XD and XE 351's (which were both rated at 200hp and had 9:1 compression) had 4bbl carbs and 4bbl 2V intake manifolds, as opposed to an early 70's 2v 351 which will make around 230hp with a 600 4bbl holley and the 4bbl 2v intake used on the XD/XE.
Which would make me suspect that the XC 351 with 2bbl intake and carb would be a fairly pitiful performer, although I would also expect Ford not to have net this slip to the public in their marketing.
Old 02-28-2002, 03:15 PM
Superdave Superdave is offline
Superdave is starting off with a positive reputation.
351C Building
Sport mode William 2015+ F150 69 01-22-2017 10:47 PM
Is this the right parts? ola1234 1973 - 1979 F-100 & Larger F-Series Trucks 1 11-23-2016 09:01 PM
My 03. Ranger xlt with the 4.0. Stalls when I put it into gear Owen Dodge Ranger & B-Series 4 09-12-2015 06:18 PM
slow accel sometimes 84-250 1994.5 - 1997 7.3L Power Stroke Diesel 2 09-26-2009 02:08 PM
v10 dry nitrous nlgcub Modular V10 (6.8l) 24 07-13-2005 05:04 PM
Tags
2v, 300, 351c, 380, ford, hp, make, nitro, produce
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
