F250 Springs on Excursion?
Today a picked up some f250 springs to hopefully cure some wander on my X.... f250 was '03 4x4 PSD, my X is '01 4x4 V10. How much lift would i likely get? Do I need to swap rears also to improve ride quality? Just curious if my tires are gonna look too small after i install 250 springs.
Stewart
Originally Posted by Stewart_H
That's gonna be news to all of us who have cured the wander by swapping out the springs on our Excursions.
joe.
If you are replacing springs that are in new condition than that is not your wander problem. However, most of our trucks have worn out springs. I need new springs all the way around but I decided to go with the RAS system, a Helwig sway bar, and new shocks for the quick fix. Later I will go with new springs.
I had just bought mine and the PO said it drove like crazy but he was selling it like it was no warranty and he did not want to look into it. It had 85k on it and all original everything. It had two blow shocks on the front. This allowed the truck to shimy. The wheels would bounce like mad. In the Jeep world we call it death wobble. So the shocks got done first. That made a big improvement but now the wander was easier to feel. I did the sway next and that helped alot but the RAS fixed it all. All were done within 3 days of each other.
Making claims like this is plain foolish, in my opinion, when faced with all the facts regarding the OEM springs on the Excursions.
Stewart
Plain and simple. If your springs are in new condittion and you have a wander problem, than the wander is not coming from your springs. I drove a new Excursion, it had no wander. However, more than just worn springs can cause a wandering problem. Poor alignment, tires, blown shocks, caster, track bar bushings.....on and on....
Using Wander as broad term to describe what a vehicle is doing does not allow enough info to correctly address his situation. He does not state mileage condition, sag, ect... about his springs. I would imagine that "All of us" that have corrected Wander on your ecxursions have replaced springs that needed to be replaced. Springs that had mileage, got soft and a bit saggy. Even if you replaced those with new Excursion springs your going to see a difference.
And foolish is telling everyone that All your problems are in your springs. That is not always the case. He does not give any info exect that he has wander. Poor tire quality and alignment can cause a wander effect. So, before you jump on me about a statement that basically confirms yours above, think it over.
stout is %100 correct in the statement made about wandering. People seem to overlook sthings such as tires. What kind of tires, what is the rating on the tire. Also people also forget that sometimes it could be what is being trailored. Bad tires on TT or bad shifted weight inside of TT. Wind resitance can cause wander. It will be different between many people. The suggestions discussed here to fix wander are all good ones but not everyone will solve their issue with just one fix as others may. Another thing swapping F250 springs will not give an X an extra 1 1/2 inches of lift. Now F350 will give you that and maybe up to 2 inches.
Once again, there is no logic to the above statement, and I again say, you're foolish to make the above claim in the face of all the data that has been collected by other members (available if you do a search here and at The Diesel Stop: Excursion forum), which proves otherwise.
I refer you to the OP's quote:
But that's not to say the steering wander wouldn't still be present. A problem that would more than likely had been cured if the Excursion springs, old or relatively new, were replaced with some F250 springs.
The OP doesn't bring any of that up because he wanted to SPECIFICALLY know about the springs he was putting on his Excursion. He NEVER asked about wander issues, generally. He asked about the springs he was specifically putting on his truck.
Stewart
Wow..... Thanks for all the replys. Seems to have gotten a little heated in here but i appreciate the info. Friday I will swap all 4 springs over, as well as the rear sway bar off the 250. Hopefully this will help, as i have already done Ball joints, shocks, alignment, and tierods in the last month. I will deal with larger tires at a later date. Thanks
Stewart, I am not going to to get into a semantical arguement with you on the net. He said he hoped to fix a wandering problem, someone said it would not, you said basically, prove it. All I said was, your both right. There is nothing wrong with someone giving advice to another and telling him, get ready, that may not be your wander problem. Have you looked into other things? have you checked out more obvious things. Now, as for Data that you seem to like so much, you have a seach button as well, I will direct you to your suggestion and say, use it. My experience is just that. You will not hear me say anything about an engine issue becuse I know very little there. However, I have been designing suspension systems and building my own for a long time. As Hemi states, I have tweaked mine alot. I probably have more heavy tow miles one small and meduim trucks thanmost on here. Now, you tell me the harm in pointing out to someone that while thier springs may be the culprit, check for other things.
And furthermore, If you are trying to intimidate another person from posting, well, this forum will end up like most of the others out there. Only a select few will post and the rest will just lurk.
