Go Back   Ford Truck Enthusiasts Forums > Newer Light Duty Trucks > 2004 - 2008 F150
Register - Join us, its Free! FAQ Members List Timeslips Calendar Mark Forums Read
2004 - 2008 F150
Is F-150 Still King?
LinkBack Thread Tools
  #1 (permalink)
Old 03-04-2008, 04:53 PM
felixr's Avatar
felixr is starting off with a positive reputation.
True Dual Exhaust Routing Under/Around Gas Tank
Question: How are you guys with true duals routing the driver side pipe? I was under there the other day and saw no place for a second straight pipe. It would have to go around the gas tank and over to the passenger side just like the stock pipe does now. Are you running two pipes side by side and then split them in an x out behind the gas tank??
__________________
Felix|04 F150 Lariat SCab 5.4L 3"HellBentSteel Lvl. Kit,Component Sys.12" Sub, 4'Whips,CB,Sat.Radio
Click
HERE to Join the Florida Chapter
(Picture doesn't work since HTML isn't allowed)
Sponsored Links
To remove this ad, register today!
  #2 (permalink)
Old 03-05-2008, 09:12 AM
felixr's Avatar
BUMP
Unrelated question: How come the edit button is not available in some posts but on others it is???
__________________
Click
  #3 (permalink)
Old 03-05-2008, 05:07 PM
mcr1994 is starting off with a positive reputation.
a u turn around the gas tank is one way....
  #4 (permalink)
Old 03-05-2008, 05:16 PM
rsylvstr's Avatar
Fleet Marine Force Doc
rsylvstr has a very good reputation on FTE.rsylvstr has a very good reputation on FTE.rsylvstr has a very good reputation on FTE.
as a sidenote, don't make the same mistake i did with my '01....
if you ever plan on installing a hitch, do it before you get the exhaust....i got the exhaust, then the hitch. I had to drop my spare a bit and wedge it in there...now it looks like a Cheby, you can see the spare.
__________________
Rob - Senior Chief, HMCS(FMF/AW), USNR(now)
2001 Screw Lariat 4x4 5.4L 4R70W 3.55 's
Cooper ATR's, Hypertech, K&N Series 77
Nasta S/S nerfs, Rancho RSX
http://www.kodakgallery.com/ShareLan..._photos_button
  #5 (permalink)
Old 03-05-2008, 06:02 PM
screwy's Avatar
Problem Developer.
screwy is gaining momentum as a positive member of FTE.screwy is gaining momentum as a positive member of FTE.
you can only edit a post for an hour after it's been made.
__________________
2008 F-150 SuperCrew Lariat, 4x4, 5.4l, 3.73 LS
Previous Trucks:
2007 F-150 SuperCrew Lariat, 4x4, 5.4l, 3.73 LS
2001 F-150 SuperCrew Lariat, 4x4, 5.4l, 3.55 LS
1996 Bronco Eddie Bauer, 4x4, 5.8l, 3.55
1993 Bronco Eddie Bauer, 4x4, 5.8l, 3.55
  #6 (permalink)
Old 03-05-2008, 11:11 PM
felixr's Avatar
hmm, interesting . . . thanks screwy
__________________
Click
  #7 (permalink)
Old 03-06-2008, 02:10 AM
tylus's Avatar
tylus is starting off with a positive reputation.
my Maggie's connect at and go back about 3? ft...then the muffler splits out to 2 pipes. the drivers side pipe squeezes between the gas tank and the spare tire while going over the axle
trust me, there is room. just most all the piping runs down the passenger side. "Y" piped or true duals
__________________
  #8 (permalink)
Old 03-06-2008, 09:53 AM
slf06150 is starting off with a positive reputation.
I ran true duals. I cut the pipe at the Y and ran them side by side all the way to the back. 05 Fx4.
  #9 (permalink)
Old 03-06-2008, 09:55 AM
felixr's Avatar
I see . . . yeah I figured they would have to run that way (side by side)
__________________
Click
  #10 (permalink)
Old 03-07-2008, 12:30 AM
tylus's Avatar
Quote:
up to the axle...yes, then they split out
there just isn't room anywhere on the drivers side of the truck before that
__________________
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is On
Trackbacks are On
Pingbacks are On
Refbacks are On
Powered by: vBulletin | Copyright ©2000 - 2008, Jelsoft Enterprises Ltd.
Ford-Trucks.com and Internet Brands, Inc. are not affiliated with the Ford Motor Company.
