Go Back   Ford Truck Enthusiasts Forums > Bronco > Early Broncos (1966 - 1977)
Register - Join us, its Free! FAQ Members List Timeslips Calendar Mark Forums Read
Is F-150 Still King?
LinkBack Thread Tools
  #1 (permalink)
Old 03-04-2008, 04:43 PM
GreenTaco is starting off with a positive reputation.
tail light connectors??
my 72 keeps burning tail light bulbs, I believe that there is a short in the harness or connectors, any body had this trouble before?
Sponsored Links
To remove this ad, register today!
  #2 (permalink)
Old 03-04-2008, 05:53 PM
RCrawler's Avatar
RCrawler is gaining momentum as a positive member of FTE.
I've never had this problem before, but you might check your sockets for rust/ poor grounding.
Jason
__________________
'93 F350 CC 4wd 7.3L 5spd, 240K miles
'69 Bronco SEFI 5.0, NP435, geared, locked...
'77 F150 4wd 351M, 435, 205
'79 F150 4wd lwb 400, 435, 205
"You can take the boy out of the trailer park, but you can't take the trailer park out of the boy."
  #3 (permalink)
Old 03-04-2008, 09:53 PM
Boba Fett is starting off with a positive reputation.
Usually your gaskets wear out and enough water/moisture gets in there and causes the buld to arc and burn out. The the gaskets look bad, replacement might be in order.
Like Crawler says, check the sockets. Especially the connector points. You can use abrasive paper to clean them up and di-electric grease for a better connection and help keep the moisture away.
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is On
Trackbacks are On
Pingbacks are On
Refbacks are On
Powered by: vBulletin | Copyright ©2000 - 2008, Jelsoft Enterprises Ltd.
Ford-Trucks.com and Internet Brands, Inc. are not affiliated with the Ford Motor Company.
