Go Back   Ford Truck Enthusiasts Forums > Regional Chapters > Western Region > Oregon Chapter
Sign in using an external account
Register Forgot Password?
Register - Join us, its Free! Albums FAQ Members Tech Guides Search Today's Posts Mark Forums Read VendorsUsed CarsGarage
Welcome to Ford Truck Enthusiasts Forums
Oregon Chapter Join Chapter, Leader: Fabmandelux
  #1 (permalink)
Old 03-04-2008, 02:49 PM
cartmanea cartmanea is offline
Garage is empty, add now
cartmanea has a great reputation on FTE.cartmanea has a great reputation on FTE.cartmanea has a great reputation on FTE.cartmanea has a great reputation on FTE.cartmanea has a great reputation on FTE.cartmanea has a great reputation on FTE.
Any code readers in Oregon?
I have an ABS light on and AutoZone's generic scanner doesn't find the codes. Does anyone have or know of a place I can get the Ford specific codes read for free? I'm really not wanting to take it to the dealership...
Thanks!
__________________
2003 F250 FX4 Sport, 6.0L Diesel, TorqShift Auto
- 4" Icon springs, Bilstein shocks,
4.30 Yukon gears, Detroit TrueTrac, Off Road Tech winch bumper
- ISSPRO EV2 Gauges (Pyro, Fuel PSI, Boost), Banks Technicooler, Garrett PowerMax VGT
Currently wrecked... again. Rebuild to come.
  #2 (permalink)
Old 03-04-2008, 05:27 PM
bertha66's Avatar
bertha66 bertha66 is offline
1966 Ford F-100
bertha66 is a name known to allbertha66 is a name known to allbertha66 is a name known to allbertha66 is a name known to allbertha66 is a name known to allbertha66 is a name known to all
I took mine to a Tire Factory, they are all over Oregon, they had a code reader for ABS and engine codes. I'm in Prineville.
__________________
Allen D
1966 F-100 4x4 with 390 GT engine
1990 Areostar 2wd XLT ext
1980 Bronco with 460
1976 F250 4X4 Custom with 429
Oregon Chapter Member: To join the Oregon Chapter, click HERE
  #3 (permalink)
Old 03-04-2008, 07:14 PM
Thanks, I'll give them a call. Did they charge you to scan it?
__________________
  #4 (permalink)
Old 03-05-2008, 04:37 PM
bertha66's Avatar
1966 Ford F-100
No, it was done for free here.
__________________
Allen D
  #5 (permalink)
Old 03-05-2008, 04:47 PM
I called the one here and they said they would charge $20-25 for reading it if I do the repairs myself. If they do repairs the reading is free.
__________________
  #6 (permalink)
Old 03-05-2008, 11:09 PM
Ponyracer Ponyracer is offline
Ponyracer has a good reputation on FTE.Ponyracer has a good reputation on FTE.Ponyracer has a good reputation on FTE.
check with Knechts they dont charge anything in Junction City so they shouldnt charge anything anywhere else. What are the symptoms besides the light being on?
  #7 (permalink)
Old 03-05-2008, 11:48 PM
ABS light is on and the ABS system doesn't work. I've locked up the rears to check it. Also, I think also caused by the ABS not working, cruise control doesn't work. I tried Autozone already, their generic code reader wouldn't read ABS codes, I'm guessing Knechts would be the same but I'll check.
__________________
  #8 (permalink)
Old 03-06-2008, 12:47 AM
it sounds like the ABS sensor that is in the rear differential housing. remove it and see if it has some metal fragments on it. You can try to clean it, remove the battery negative cables for ten minutes to clear codes and test drive. if this doesnt work replace the sensor. it is the most common trouble unless something is still unplugged or came unplugged because of the accident. in that case check all conections at the front of the vehicle around the ABS assembly which is probably near the left front or right front frame rail. email me with what you find. I used to be a factory Ford Master technician. if you dont find anything play the starving student thing and call the local dealership and see if you can talk them into having the shop foreman pull the codes for free.
  #9 (permalink)
Old 03-06-2008, 01:40 AM
Thanks for the advice. I'm really thinking it might be the front right sensor since that wheel took a pretty hard hit. (Sheared the center pin off the leaf springs, uncurled the military wrap, and bent the spring hanger.) I'm going to try to get a friend who works at a dealership to read it while on spring break in two weeks, if that doesn't pan out I'll play the poor college student
__________________
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Forum Jump
Powered by vBulletin® Version 3.7.5
Copyright ©2000 - 2013, Jelsoft Enterprises Ltd.
SEO by vBSEO 3.5.2 ©2010, Crawlability, Inc.
vbulletin Admin Backup
