Go Back   Ford Truck Enthusiasts Forums > Small Chassis Trucks > Bronco II
Register - Join us, its Free! FAQ Members List Timeslips Calendar Mark Forums Read
Is F-150 Still King?
LinkBack Thread Tools
  #1 (permalink)
Old 03-04-2008, 02:48 PM
ford_4.0's Avatar
ford_4.0 is starting off with a positive reputation.
My Dad has a problem.
My dad has a '89 with the 2.9 (I think thats what it is). Last wednesday he came home from work with this wierd clicking noise coming from the underside. it almost sounds like a metal tag geting hit with something. it'll do it real lightly just idleing, and you can hear it on the road, but it really starts to make a racket when you gun it or let it bog down when you take off. It's not real constant, but it's always there. Any Ideas?
Sponsored Links
To remove this ad, register today!
  #2 (permalink)
Old 03-04-2008, 04:58 PM
mrshorty is starting off with a positive reputation.
First thoughts are:
Exhaust heat shield rattling
Spark leak from wires/plugs
Exhaust leak
__________________
'87 Bronco II XLT 4x4 & '92 Explorer XLT 4x4 & '98 Chev Suburban K1500 SLT 4x4
  #3 (permalink)
Old 03-05-2008, 01:33 PM
ford_4.0's Avatar
we already checked for loose plugs, and it doesn't sound like a exhaust leak. I'll chech the heat shield. thanks
  #4 (permalink)
Old 03-05-2008, 02:30 PM
Help I M Stuck is starting off with a positive reputation.
Check ALL U-joints.
__________________
-Jeff
86 Bronco II 4inch suspesnion lift, 3inch body, 35x12.50x15 BFT AT/s and 4:10gears.
05 F250 Superduty Diesel--tows the BII to the trails
  #5 (permalink)
Old 03-05-2008, 05:48 PM
ford_4.0's Avatar
The sound is there when it isn't moving too.
  #6 (permalink)
Old 03-05-2008, 06:10 PM
Lead Head is gaining momentum as a positive member of FTE.Lead Head is gaining momentum as a positive member of FTE.
Probably rod or valve knock.
  #7 (permalink)
Old 03-05-2008, 06:47 PM
my72ford is starting off with a positive reputation.
it may be the famed valve tick,since these 2.9's are known for top end noise
__________________
Current Rides
1972 f100 ranger xlt shortbed 302/auto 285,000
2004 ford freestar {the kidvan}
1986 bII 2.9 5spd 214,000 finally retired! currently rebuilding engine,hopefully running soon
1993 ford aerostar 307,000 going strong
  #8 (permalink)
Old 03-05-2008, 08:54 PM
Ranger 4X4 King is starting off with a positive reputation.
My dad just worked on his engine sounds like the same problem he had. When we took it apart we foud a bent rod (two different directions)and broken piston. He was fortunate nothing as far as the engine block was damaged. Looking to start it up some time this week.
  #9 (permalink)
Old 03-07-2008, 01:00 PM
ford_4.0's Avatar
I hope it isn't anything like a dead piston or something of the likes, but I think my dad has decided to just tear it down and rebuild it. thanks for helpin out.
  #10 (permalink)
Old 04-18-2008, 02:28 PM
ford_4.0's Avatar
Found out what the noise was. The starter doesn't use a solenoid to engage it onto the flywheel, instead syntrifical force is used. The spring to keep the little gear on the starter back away from the flywheel had broke, allowing the gear to bounce around.
We had to laugh when we found this a few weeks ago. If not for having to take the starter off when pulling the motor we probubly never would have found it.
  #11 (permalink)
Old 04-18-2008, 08:34 PM
glad to hear you found the problem. at least you didn't tear the entire engine down!!
__________________
Current Rides
  #12 (permalink)
Old 04-19-2008, 08:22 AM
Eddiec1564 is starting off with a positive reputation.
The same thing happened on my B2, make sure the flexplate gear is not chewed up!
  #13 (permalink)
Old 04-23-2008, 02:51 PM
Sure is good that you didn't have to tear down the engine. Dad has his running it's doing great.
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is On
Trackbacks are On
Pingbacks are On
Refbacks are On
Powered by: vBulletin | Copyright ©2000 - 2008, Jelsoft Enterprises Ltd.
Ford-Trucks.com and Internet Brands, Inc. are not affiliated with the Ford Motor Company.
