Go Back   Ford Truck Enthusiasts Forums > Older, Classic & Antique Trucks > 1961 - 1966 F-100 & Larger F-Series Trucks > 1961 - 1963 F100 Unibody
Sign in using an external account
Register Forgot Password?
Register - Join us, its Free! Albums FAQ Members Tech Guides Search Today's Posts Mark Forums Read VendorsUsed CarsGarage
Welcome to Ford Truck Enthusiasts Forums
1961 - 1963 F100 Unibody 1961, 1962 and 1963 Ford F100 Unibody trucks
  #1 (permalink)
Old 03-04-2008, 12:46 PM
squezdawg squezdawg is offline
Garage is empty, add now
squezdawg is starting off with a positive reputation.
Question '63 f-100 vin#
Any one know where I can find the vin# on my 1963 ford f-100?
  #2 (permalink)
Old 03-04-2008, 12:50 PM
airharley's Avatar
airharley airharley is offline
airharley is gaining momentum as a positive member of FTE.
Welcome to FTE. There are a few places to find it actually. One being on the edge of the drivers side door opening. The other is on the passanger frame rail between the front axle and the firewall. It will be stamped and over time dirt and paint fill in the stamping so you can't see it that well.
__________________
Mark J. Covill
"I'm not handicapped, I'm handicapable!"
'64 F-100 Shortbed 460/C-6
Author of the disc brake article for 57-64 F-100's
  #3 (permalink)
Old 03-04-2008, 12:52 PM
NumberDummy's Avatar
NumberDummy NumberDummy is online now
Ford Parts Guru
2013 Ford Escape
NumberDummy has a superb reputationNumberDummy has a superb reputationNumberDummy has a superb reputationNumberDummy has a superb reputationNumberDummy has a superb reputationNumberDummy has a superb reputationNumberDummy has a superb reputationNumberDummy has a superb reputationNumberDummy has a superb reputationNumberDummy has a superb reputationNumberDummy has a superb reputation
Quote:
Welcome to FTE
Two possible locations: Either on the inside of the glove box door (early 1963's), or on the left door face near the latch.
The number is also stamped on the top of the right frame rail in front of the cab.
The VIN is what your truck is registered with. It should be on the title.
Door VIN's: It sometimes doesn't match what's on the registration. 1961/66 doors are all the same, and due to damage, some ppl swapped doors, and forget to change the Warranty Plate...where the VIN is located.
__________________
Bill // Retired Ford Parts Manager // SoCal Chapter member // Part Number Research: 1928/2001 FoMoCo vehicles.
2013 Escape SE FWD 2.0L Eco-Boost.
  #4 (permalink)
Old 03-05-2008, 01:20 AM
camperspecial65 camperspecial65 is offline
camperspecial65 has a good reputation on FTE.camperspecial65 has a good reputation on FTE.camperspecial65 has a good reputation on FTE.
slight correction to Bills post above...the fit/function of the doors are same 61-6 as mentioned, but the body line is straight on the unibody trucks and have the drop down area on the 64-6 doors if Im not mistaken...Im not for sure on the non unibody 61-3 trucks though...minor detail though if its a work truck.
- cs65
Tags
1961, 196166, 1963, 1966, codes, doors, f100, fit, ford, frame, location, number, reading, truck, vin
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is On
Trackbacks are On
Pingbacks are On
Refbacks are On
Forum Jump
Powered by vBulletin® Version 3.7.5
Copyright ©2000 - 2013, Jelsoft Enterprises Ltd.
SEO by vBSEO 3.5.2 ©2010, Crawlability, Inc.
vbulletin Admin Backup
