Go Back   Ford Truck Enthusiasts Forums > Performance, Engines and Troubleshooting > Engine Swaps
Register - Join us, its Free! FAQ Members List Timeslips Calendar Mark Forums Read
Is F-150 Still King?
LinkBack Thread Tools
  #1 (permalink)
Old 03-04-2008, 12:47 PM
sneak is starting off with a positive reputation.
Swap Virgin... 6.8L JD Diesel into 76 250 cmprspcl 2wd
I'll post some more info when I get time, feel free to give me your ideas.
__________________
1976 F-250 Camper Special - does not run
1977 F-150 Northland Edition - does not run
2002 F-350 Powerstroke
1996 Ranger 2wd 4cyl manual - daily driver
Diamond-T 5-ton truck - does not run (May recieve a DT466 in the future)
Sponsored Links
To remove this ad, register today!
  #2 (permalink)
Old 03-04-2008, 09:25 PM
92f150I6's Avatar
92f150I6 is starting off with a positive reputation.
Sounds like a good idea if it will fit and you have a way to hook up a trans. I also figuring that you will need some suspension work as well to handle the weight.
__________________
2003 F250 SD 4X4 5.4L 4:10 Arizona Beige
1987 Mustang GT
A bunch of motorcycles, other cars, and a Quad.
  #3 (permalink)
Old 03-04-2008, 11:09 PM
nevrenufhp is starting off with a positive reputation.
http://rides.webshots.com/album/5583...ions/FullAlbum
Here's a little motivation. It's an IH, but will be about the same difficulty to fit.
__________________
turn up diesel fuel rate site of mine
67 F100, 300, 4spd, Offy 'C', Edelbrock 500, heddder.
Project: 99 Stupor Duty F250, 2WD, AT545, waiting for DT466(IH power)
  #4 (permalink)
Old 03-06-2008, 03:13 PM
Ford4x4-JD70AB's Avatar
Ford4x4-JD70AB is starting off with a positive reputation.
sounds like a pretty sweet swap if it all will work. Any thoughts to what transmission you are going to use? Ive played around with the thought of swapping a JD 4.5L in my f150.
__________________
1995 Ford F-150
Black/Silver-Extended Cab-4x4-302cid
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is On
Trackbacks are On
Pingbacks are On
Refbacks are On
Powered by: vBulletin | Copyright ©2000 - 2008, Jelsoft Enterprises Ltd.
Ford-Trucks.com and Internet Brands, Inc. are not affiliated with the Ford Motor Company.
