Go Back   Ford Truck Enthusiasts Forums > Performance, Engines and Troubleshooting > Ford V6 > 2.6, 2.8, 2.9, 4.0 and SOHC 4.0 V6
New! Use your Facebook, Google, AIM & Yahoo accounts to securely log into this site, click logo to login
Is F-150 Still King?
  #1 (permalink)
Old 03-04-2008, 08:05 AM
alaskanflick alaskanflick is offline
alaskanflick is starting off with a positive reputation.
2.9 timing mess
First off, it's not my fault, second I need to get this bronco II running. A family friend brought her car over to do plugs, wire, cap and all on her 88, she likes being a grease monkey so I just watched mostly, she did the wires first one by one and marking them, then she did the plugs, then she marked the numbers on the new cap... and proceded to twisting the old one into a better position to get the nut driver on it.... She had her clutch replaced a year ago and noticed a little rough driving for a few days but it straightened out, the best I can figure is that the shop knocked the clamp lose and it's been working due to the memory of the wires holding it in place.
So all said and done we go through with everything and set it to our best guest and the thing doesn't want to start, so I yell at her to stop turning it over, but she's standing next to me with the key. 2 minutes of diesleing later with battery leads off and smoking, I have the #2 plug cracked, an electrical burn across my hand and a renewed belief in new cars and warranties.
What damage could possibly be done? What are my next steps to getting the first problems fixed? I'm pretty sure we didn't lift the distributor out at all but how do you fix that? And what the correct timing setting for this engine 10 or 8.
  #2 (permalink)
Old 03-04-2008, 01:33 PM
floydguy floydguy is offline
floydguy is starting off with a positive reputation.
first of all, recheck your firing order, 1-4-2-5-3-6 clockwise and the timming is 10 degrees btdc. for 2.9. youd have to remove bolt and clamp to lift distributor, check to see if its loose , did the distributor turn?
  #3 (permalink)
Old 03-04-2008, 02:41 PM
Lead Head Lead Head is offline
Lead Head has a good reputation on FTE. Lead Head has a good reputation on FTE. Lead Head has a good reputation on FTE.
the 88 2.9 should be EFI, at least my 87 is. If it was dieseling for 2 minutes after you turned the key off, something is seriously wrong.
The only other thing that comes to mind is a short out somewhere, causing the ignition to stay on, if I take the battery cables off my on my ranger, while shes running, it will stay running.
  #4 (permalink)
Old 03-05-2008, 09:38 AM
TigerDan's Avatar
TigerDan TigerDan is offline
1968 Ford F-250
TigerDan has a brilliant future TigerDan has a brilliant future TigerDan has a brilliant future TigerDan has a brilliant future TigerDan has a brilliant future TigerDan has a brilliant future TigerDan has a brilliant future TigerDan has a brilliant future TigerDan has a brilliant future TigerDan has a brilliant future TigerDan has a brilliant future
Hi, Welcome to the site!
As mentioned, make sure the plug wires are in the correct positions on the cap. Below is a diagram of the 2.9 layout.
Is the cap secure on the distributor now? Not able to move around anymore, I hope...? The cap is held onto the distributor with screws, not clamps so it would be pretty hard to accidently knock them loose, I'd check to see that the distributor itself is secure. The diagram below shows pretty closely where you want the distributor set, and you can also aim the TFI module so that it's parallel to the firewall.
__________________
FTE Moderator
Stop by and see us in the
Northern California Chapter!
"alot" is not a word...
Political Correctness is a doctrine, fostered by a delusional, illogical minority, and rabidly promoted by an unscrupulous mainstream media, which holds forth the proposition that it is entirely possible to pick up a turd by the clean end.
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is On
Trackbacks are On
Pingbacks are On
Refbacks are On
Guidelines - Contact Us - Ford Truck Enthusiasts - Archive - Top
Powered by: vBulletin | Copyright ©2000 - 2010, Jelsoft Enterprises Ltd.
