Have you registered for your free membership? If not, click here now to register!
Join Our Site - Its free, quick and easy!
Click Here to join.   Click Here for more information
Users Chatting None
Go Back   Ford Truck Enthusiasts Forums > Diesel > Competition
Register - Join us, its Free! FAQ Members List Timeslips Calendar Mark Forums Read
Competition Diesel racing, sleds, dynos, power tuning and max performance.
Is F-150 Still King?
Reply This Section Sponsored By
LinkBack Thread Tools
  #46 (permalink)
Old 03-05-2008, 09:09 PM
SUPERDUTY_untouchabl's Avatar
SUPERDUTY_untouchabl is gaining momentum as a positive member of FTE.
blk99 you might wana re-phrase your sentace from PSD. Matt already has a 6.4 over the 500hp mark with a complety stock truck with the dpf removed and his tunes. 500hp with a motor that has been out less than a year, it is looking good in the performance department of the 6.4's.
__________________
-Josh
04 F150 4.6l 2wd reg cab XL 3:55 LS SISO Flowmaster S40 NCD Customs 2.5" Leveling Kit Burner High Power Fog Lights
85 Bronco 5.8l 351w 4wd Gas Guzzler
  #47 (permalink)
Old 03-06-2008, 07:58 PM
imelmo is starting off with a positive reputation.
Who did the tuning on that (what company)? I haven't read who did the tuning yet.
  #48 (permalink)
Old 03-06-2008, 09:37 PM
If you are talking about my post it was Matt from Spartan Diesel. He has a 210hp tune out right now that is putting the 6.4 over the 500 rwhp mark and is currently working on a 240hp tune. This is with a complety stock truck with the dpf removed.
He did say though a aftermarket intake helps it out abunch.
__________________
-Josh
  #49 (permalink)
Old 03-06-2008, 10:25 PM
jtharvey's Avatar
Destroking it
jtharvey has a good reputation on FTE.jtharvey has a good reputation on FTE.jtharvey has a good reputation on FTE.
Josh, does he have dyno sheets, timeslips, or something to verify the claim? If that new motor is capable of that much power with just a chip and exhaust removal, that's impressive.
__________________
Jeremy
2000 F-350 CCLB SRW 4x4, Dropping in a CR 5.9 .... because my Forged Rod 7.3 blew up at 430 HP!
UPDATED - 7.3 Engine Parts for sale, both performance and stock parts: FTE Classified Ad
New engine:
See My Pics for more.
  #50 (permalink)
Old 03-07-2008, 08:04 AM
cookie88's Avatar
cookie88 is a splendid one to beholdcookie88 is a splendid one to beholdcookie88 is a splendid one to beholdcookie88 is a splendid one to beholdcookie88 is a splendid one to beholdcookie88 is a splendid one to behold
Quote:
Makes you wonder why we waste our time with the old school tech.
http://www.ford-trucks.com/forums/70...o-numbers.html
__________________
Scott - FTE moderator
01 F-250 Lariat, 7.3, ZF-6, NV271, -38R, SII splits, DI tunes, Custom fuel, IDM140....and more little mods than I can remember.
79 Bronco- 7.3 IDI diesel project truck
96 Merc Grand Marquis (hers) mostly stock 4.6
68 Merc Montego completely stock s-code (275HP 2bbl) 390
  #51 (permalink)
Old 03-07-2008, 09:49 AM
jtharvey's Avatar
Destroking it
Impressive. Makes me wonder what will be the weak link[s] in the new engines.
__________________
Jeremy
New engine:
  #52 (permalink)
Old 03-07-2008, 11:13 AM
Lol so far it has no weak links. Matt said that even the tranny has not slipped once with his 240 tune he is working on. And it is outside of its torque rating. He also said that on the older torq shifts it would slip with that much power but the ones on the 08's dont for some reason.
__________________
-Josh
  #53 (permalink)
Old 03-07-2008, 06:58 PM
cookie88's Avatar
Indeed....Time will tell.
__________________
  #54 (permalink)
Old 03-13-2008, 06:18 PM
FullBoost is starting off with a positive reputation.
Heres the dyno sheet.
  #55 (permalink)
Old 03-16-2008, 10:22 PM
duramaximizer is new and has a neutral reputation at this point.
The problem with a dyno in general is that it is a false addiction. Okay, so you can make hp on a dyno and torque on a dyno. What does it prove in the application for which it was designed? I personally like dyno's as a tool, but the real world is much different. Track times prove power the the ground, track distances prove power to the ground, towing proves power to the ground or it accomplish a goal in my mind. Dyno's prove possible potential, nothing more and nothing less in my mind.
If you run the dyno and make it's lies the major goal, it seems to me like you're playing with a lab rat. There is a lot to learn, but a smaller amount of it is actually useable.
Correction factors to me have always been an excuse to claim a higher hp then you actually made.
  #56 (permalink)
Old 04-12-2008, 09:58 PM
Orezona's Avatar
EyeBalls!ClickSir!
Orezona is gaining momentum as a positive member of FTE.
The new " FTE Smack Talk"
__________________
Jason
4" Straight Pipe, Gauges, DIY Fuel Crossover Bleed-Off, In-Tank Pre-Pump, DAHL 150, Carter Lift-Pump, Boost Anihilator, High-Flow Outlet, ATS Ported Shroud, DieselSite Boots, F5 NoStart/Stock/40tow/80econo
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is On
Trackbacks are On
Pingbacks are On
Refbacks are On
Powered by: vBulletin | Copyright ©2000 - 2008, Jelsoft Enterprises Ltd.
Ford-Trucks.com and Internet Brands, Inc. is not affiliated with the Ford Motor Company.
© 1997-2007 Internet Brands, Inc., Please see our Terms of Use / Privacy Policy
