Have you registered for your free membership? If not, click here now to register!
Join Our Site - Its free, quick and easy!
Click Here to join.   Click Here for more information
Users Chatting None
Go Back   Ford Truck Enthusiasts Forums > Performance, Engines and Troubleshooting > Engine Swaps
Register - Join us, its Free! FAQ Members List Timeslips Calendar Mark Forums Read
Is F-150 Still King?
LinkBack Thread Tools
  #1 (permalink)
Old 03-03-2008, 09:15 PM
Hillcapper is starting off with a positive reputation.
4.9 to 5.0/5.8
I'm about to buy either the 5.0 or 5.8 to replace my 4.9. Found a pretty good deal on a 5.8 so I'm leaning that way now (I cant believe how indecisive I am on this). I've gotten good input from some of you all, Conanski and Kemicalburns in particular.
Questions; with either of these engines replacing my 4.9, will I need to change engine pedastools or just relocate the 4.9 pedstools?
Are these available aftermarket or do I have to get them from the bone yard?
Anything else needed besides engine wiring harness and computer that should come from a donor vehicle?
Running same 5 speed so I am assuming current radiator will work ok?
Thanks,
Craig
Sponsored Links
To remove this ad, register today!
  #2 (permalink)
Old 03-03-2008, 10:32 PM
wedefyu's Avatar
wedefyu is starting off with a positive reputation.
Make sure you get the correct flywheel, if you try to run the 4.9 flywheel on a 5.0 or 5.8 you'll have a vibration that will make short work of your crank bearings.
I don't know what year your truck is but since you said 4.9 instead of 300 I presume it's a fuel injected motor and a lot newer then my truck. But in my 77 F100 the small block ford bolted right to the old 300 motor mounts.
__________________
Josh
79 F'150 302 NP435/205
79 Bronco 400M/NP203
67 F100 352 Auto 2wd
72 F100 302 Auto 2wd
  #3 (permalink)
Old 03-04-2008, 08:10 AM
Conanski's Avatar
Conanski has a good reputation on FTE.Conanski has a good reputation on FTE.
I believe the water outlets are opposite sides on the rad for the I6 and V8's, so a V8 rad would enable the use of stock rad hoses but I bet you could make the I6 rad work. Engine mounts are different, and there's the exhaust to consider as well.
__________________
Paul O
1990 F150 4x4 XLT Extended Cab (Currently undergoing a heart transplant)
1990 Ranger 2wd, 2.3 Briggs & Stratten, 5-speed, 3.08
  #4 (permalink)
Old 03-04-2008, 06:11 PM
havi's Avatar
Certified Anomaly
havi is gaining momentum as a positive member of FTE.
You say 5.0 or 5.8 and 4.9, 5 speeds, etc...this tells me you have a newer truck/bronco. Ford used crossflow rads. in these years, so yes, the 4.9 had both outlets on the driver side, and the 5.0 has the top one on the passenger side/lower on driver side. Again, being newer, I can't tell about the perches, but in the 70's you had to change the 300 perches out for the windsor/335 series engines. My 2 cents would be to keep tabs on/buy the whole truck(then part out or sell the rest for scrap)and the wiring and computer are all there for the taking, along with accessory brackets, exhaust, rad., etc...
__________________
Time, Money, Energy: Pick any two
The List: http://s320.photobucket.com/albums/nn337/havi_62meteor/
  #5 (permalink)
Old 03-04-2008, 08:24 PM
92f150I6's Avatar
92f150I6 is starting off with a positive reputation.
I would definitely recommend swapping in the 5.8 L motor, as the 5.0 is not a real improvement over the 4.9 unless you modify it.
__________________
2003 F250 SD 4X4 5.4L 4:10 Arizona Beige
1987 Mustang GT
A bunch of motorcycles, other cars, and a Quad.
  #6 (permalink)
Old 03-04-2008, 08:33 PM
Sorry I didnt give all the info. 1994 F150 2wd short bed with 4.9 and 5 speed. Going back with 5 speed and EFI either 5.0 or 5.8.
Conanski, when you say motor mounts you dont mean the frame perches do you? Will I need the perches out of donor truck or reposition exisiting perches?
I'll be going with some sort of header setup and aftermarket exhaust. So I'll be picking everyones brain about that at some point.
  #7 (permalink)
Old 03-05-2008, 04:06 PM
Back to top, need some help on the frame 'perches' for the V8
  #8 (permalink)
Old 03-05-2008, 04:16 PM
Kemicalburns's Avatar
Kemicalburns is gaining momentum as a positive member of FTE.Kemicalburns is gaining momentum as a positive member of FTE.
302 frame perches would work for both 302 or 351w
__________________
94 XLT 5.8/E4OD
6"ProComp Stage II 35x12.5x15 BFG MT's ,
4.88 gears f/r
installing soon: JBA shorty, Bassani Y pipe, Edelbrock efi truck intake, , aussie front/rear
88 (Rolled)
http://www.supermotors.org/registry/vehicles/detail.php?id=4158
  #9 (permalink)
Old 03-05-2008, 04:51 PM
andym's Avatar
andym has much to be proud ofandym has much to be proud ofandym has much to be proud ofandym has much to be proud ofandym has much to be proud ofandym has much to be proud ofandym has much to be proud ofandym has much to be proud of
The 300 perches are different. Also, listen to the advice above about not going to the 5.0. You will be disappointed and will wish for the 300 to be back under the hood.
Also, since you're re-using the M5OD, be aware that Ford never offered this combination. The 351 may or may not be too much for the M5OD. It really depends on how you drive it. I think that if you dump the clutch a few times you will be back here asking "What transmission can I use with a 351?"
__________________
Andy
1989 F-150 XLT Lariat Shortbed 4x4 300/T-18/3.55
1990 Bronco Eddie Bauer 4x4 351/E4OD/3.55
Quote:
Originally Posted by lenny1carl
you were born a flat footed, tiny black gay dude that speaks spanish.
  #10 (permalink)
Old 03-05-2008, 07:26 PM
Thanks all, didnt even consider the tranny with a 5.8, something else to think about.
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is On
Trackbacks are On
Pingbacks are On
Refbacks are On
Powered by: vBulletin | Copyright ©2000 - 2008, Jelsoft Enterprises Ltd.
Terms of Use - Privacy Policy - JOBS
Ford-Trucks.com and Internet Brands, Inc. is not affiliated with the Ford Motor Company.
© 1997-2007 Internet Brands, Inc., Please see our Terms of Use / Privacy Policy
