Steering prob. after upper con. arm replmnt. - Ford Truck Enthusiasts Forums
Ranger & B-Series All Ford Ranger and Mazda B-Series models
Old 03-03-2008, 07:55 PM
66fdtrucknut 66fdtrucknut is offline
66fdtrucknut has a great reputation on FTE.66fdtrucknut has a great reputation on FTE.66fdtrucknut has a great reputation on FTE.66fdtrucknut has a great reputation on FTE.
I have a 99' Mazda B2500, replaced upper control arm/ball joint, very easy job. After dropping the truck down and backing out of the garage I noticed a shuddering in the steering when I turn the wheel either sitting still or moving. Is it because of the ball joint being new and tight? Could the front end be that out of alignment? Any input apprec.
Charlie
Old 03-03-2008, 08:39 PM
quiktrp quiktrp is offline
quiktrp is starting off with a positive reputation.
You probably turned the wheel with the engine off. With this style PS pump, that can introduce air into the system causing the shudder you feel. Try topping off the fluid and driving for a bit. It might improve on it's own. Otherwise you;ll have to vacuum bleed the steering system. I think OTC sells a vacuum adapter. You'll use it with a hand pump. If it comes to that, post back and I can give directions on how to do it.
Old 03-03-2008, 09:06 PM
You're right I did, I turned the wheel when I torqued the arm bolts, thats why these forums are great. Thanks.
Charlie
Old 09-21-2012, 02:39 PM
Nite Ranger Nite Ranger is offline
Nite Ranger is starting off with a positive reputation.
Add me to the list of those with this steering shudder problem after front end work was done.
99 Ranger 4 cyl.
I just did a brake job on it. With the engine off I turned the wheel right and left to replace the rotors and calipers. When done I backed it out of the garage and immediately upon turning left I got that dreaded shudder. Only to the left however. I drove it a few miles and it didn't get any better. Now upon researching this I see numerous suggestions on how to get rid of the air. Since it has never had the ps fluid replaced I'll probably do the flush and see.
Old 09-22-2012, 06:11 PM
Well after a couple of days of city driving the shudder is almost gone. I didn't have to do anything to it. But.....
I traded that dude off today.
2001 Ranger Upper Ball Joints Replaced But Now Steering Wheel Shakes? CountryGirl3294 Ranger & B-Series 6 01-10-2012 02:29 PM
HELP WITH BALL JOINT REPLACEMENT magnet1 2004 - 2008 F150 9 06-30-2011 09:24 PM
ford ranger ball joint oops Ranger & B-Series 11 04-16-2010 04:59 PM
upper&lower ball joints shade1965 1980 - 1986 Bullnose F100, F150 & Larger F-Series Trucks 6 03-04-2010 06:12 PM
99 4WD Expedition, changing lower ball joints VTBoater 1997-2006 Expedition & Navigator 7 12-14-2007 07:57 AM
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
