F-250 Steering Play !!!! - Ford Truck Enthusiasts Forums
1999 to 2016 Super Duty 1999 to 2016 Ford F250, F350, F450 and F550 Super Duty with diesel V8 and gas V8 and V10 engines
Old 03-03-2008, 08:47 PM
BIGGMIKE BIGGMIKE is offline
BIGGMIKE is starting off with a positive reputation.
I looked in the search section for steering play and find all kinds of problems ranging from bad steering boxes to pitman arms and steering stabilizer bars. First of its a 2004 F-250 Harley truck 4x4 WHEN DRIVING DOWN THE ROAD ITSEEM TO WANDER BACK AND FORTH. it pulls to the left then when i staighten it itkind of goes the other way. wierd I just put new tires on it same thing also an alignment. the toe was off but it still wanders. any help would great!!!! thank you
Old 03-03-2008, 09:42 PM
F350-6's Avatar
F350-6 F350-6 is offline
F350-6 has a superb reputationF350-6 has a superb reputationF350-6 has a superb reputationF350-6 has a superb reputationF350-6 has a superb reputationF350-6 has a superb reputationF350-6 has a superb reputationF350-6 has a superb reputationF350-6 has a superb reputationF350-6 has a superb reputationF350-6 has a superb reputation
Welcome to FTE. Did the problem just start with the new tires? Or was it there before? How long have you had the truck, and has it always done this?
If you're new to a Superduty, then they do handle different than a half ton or car. Since we have our own funny language here you might also try searching for "Death wobble"
Some trucks have this, and that's what most refer to it as.
Old 03-03-2008, 09:43 PM
redford's Avatar
redford redford is online now
redford has a superb reputationredford has a superb reputationredford has a superb reputationredford has a superb reputationredford has a superb reputationredford has a superb reputationredford has a superb reputationredford has a superb reputationredford has a superb reputationredford has a superb reputationredford has a superb reputation
Sounds like the caster setting is off.
Old 03-04-2008, 08:59 AM
Just bought the truck 2 weeks ago, put new tires on 2 days ago and it feels like a drunken weave back and forth
Old 03-04-2008, 09:18 AM
redford's Avatar
Was it like this when you purchased the truck, or did it start when you put the tires on it?
Old 03-04-2008, 09:34 AM
fcfirefighter05 fcfirefighter05 is offline
fcfirefighter05 is starting off with a positive reputation.
One thing I found with my truck not to long ago was the pitman arm was worn-replaced it, and the steering gear needed to be adjusted....helped a good bit...this could help you. One thing to see is get someone in the seat moving the steering wheel back and forth while you look under the front for any joints with slack in it...doesn't take much slack to make a big difference. To check the steering box, see whether the pitman arm moves "tight" with the steering wheel, or if when changing directions, there is slack there...do all this with the motor off. Hope it helps
Old 03-07-2008, 04:37 PM
put brad new steering stabilizer bar on, (didnt have one on there) same thing going to try to adjust the steering box tonight. The new tires went on after I bought it and after thealignment
Old 03-07-2008, 04:40 PM
RussB's Avatar
RussB RussB is offline
RussB has a good reputation on FTE.RussB has a good reputation on FTE.
Mine does the same.. I have to check it all out as well.. another thing to check I think would be the track bar bushings !! they might be a bit loose and I've heard that it might make the truck wander !!
Old 03-07-2008, 06:02 PM
jokerforever's Avatar
jokerforever jokerforever is offline
jokerforever is gaining momentum as a positive member of FTE.jokerforever is gaining momentum as a positive member of FTE.
If there is something lose in the steering a stabilizer won't make a difference. I had this same problem and replacing everything from the box to the tie rods. I fought that steering for three years. It ended up being the balljoints. I donít know what made me feel dumber; the fact that I didnít think about that or that the one that found it was some young punk at the Firestone shop when I took it in to have the rotors turned.
Do what Firefighter said; have a friend move the steering wheel back and forth and watch to see what moves. It could be in the tie rods, ANY bushing in the suspension, the box, or the steering shaft. If you canít see anything jack the frontend and see if there is any play at the tires. You might need a pry bar to check the balljoints.
Oh and if the box is loose donít crank down on the adjustment screw. If you tighten too much it will raise the PS fluid pressure and youíll bust youíre lines.
Old 03-07-2008, 06:26 PM
elmo8641 elmo8641 is offline
elmo8641 is starting off with a positive reputation.
my ball joints are to tight. it makes it so that the truck does not return to center. kinda wonders over the road because it never will go back to center. if you remove your tie rod ends from the knuckle and try to turn the wheel. if it is hard to turn then the ball joints are prob. bad. not loose but to tight.
Old 03-07-2008, 07:10 PM
jeffdoerr jeffdoerr is offline
jeffdoerr is starting off with a positive reputation.
I had the same problem with my 99. Changed EVERYTHING related to steering, it was never perfect, but was probly 50% better. I was told by a Ford mechanic that reman steering gear boxes are usually not the way to go, he recommend that I buy a new Ford part. Well, reman was half the price, thats what I used, in fact, I changed it twice in a year. While these trucks do handle different, that is no reason for the awful wander in the steering. My 06 does not do that, it drives like it should.
I did finally solve the steering problem and have not had a problem since. I sold it last november.
1986 F250 steering wandering. FordFETruck 1980 - 1986 Bullnose F100, F150 & Larger F-Series Trucks 11 05-14-2012 11:51 PM
wandering 02 f250 7.3 4x4 omahaford 1999 - 2003 7.3L Power Stroke Diesel 1 03-28-2012 08:44 PM
Looking for a New/Rebuilt Steering Box 2006 F250 and Wandering cc35mki 1999 to 2016 Super Duty 4 01-15-2012 03:54 PM
2004 F250 Steering problem - wander/hunting rboett3930 Brakes, Steering, Suspension, Tires, & Wheels 4 11-15-2010 11:44 PM
alignment, wandering problem solved 64F260 1999 - 2003 7.3L Power Stroke Diesel 12 02-19-2010 10:11 PM
Tags
2002f350, 250, ford, play, steering
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Forum Jump
This forum is owned and operated by Internet Brands, Inc., a Delaware corporation. It is not authorized or endorsed by the Ford Motor Company and is not affiliated with the Ford Motor Company or its related companies in any way. Fordģ is a registered trademark of the Ford Motor Company.
