Go Back   Ford Truck Enthusiasts Forums > Performance, Engines and Troubleshooting > Modular V8 (4.6L, 5.4L)
Register - Join us, its Free! FAQ Members List Timeslips Calendar Mark Forums Read
Is F-150 Still King?
LinkBack Thread Tools
  #1 (permalink)
Old 03-03-2008, 08:21 PM
Silverdawg's Avatar
Silverdawg is starting off with a positive reputation.
Where'd my coil packs go?
Long story short: I've been chasing water around my ignition coils for a few months. I lost #1 a month ago. We've since had a foot of slush and slop and now it's misfiring again. So, I was out tonight putting dielectric on the boots and something struck me. I have no coil packs! They SHOULD be on brackets at either side of the front of the block right? I'd never noticed them before. All I have are the rusty studs where the packs should be. So, where'd they go? Could the be in the back?? Or did they leave for Florida without me?
Or is the Chilton book THAT bad? Sometimes I think I'd be better off with nothing than the Chilton book.
- S-dawg
Sponsored Links
To remove this ad, register today!
  #2 (permalink)
Old 03-03-2008, 08:48 PM
galaxie641 is starting off with a positive reputation.
Well looking at your profile I assume this is on a '00, if so you have no coil packs you have individual coils on each plug and thats it.
__________________
'48 F1 Flat6
'51 F3 Flat8
'64 Galaxie 352 4bbl
'68 F150 390
'72 F250 400/C6
'97 F150 5.4L
  #3 (permalink)
Old 03-03-2008, 09:20 PM
Silverdawg's Avatar
I see now. The stupid book had me thinking that a COP equipped 4.6L engine would also have coil packs - which seemed riddiculous. So, I don't have to worry about water getting into coil packs. I've dielectric slathered EVERYTHING involving the COPS and ignition wiring. Hopefully that wil fix the issue.
Incidentally, are there any other ignition harnass parts that could pose a problem with misfires after driving in rain and slush? You'd think a 4x4 truck would be capable of being driven in something like that, however, mine reverts to a lurching, shuttering, sputtering 7 (or fewer) cylinder mess whenever I drive in even a drizzle. I'm getting sick of having to drive the Civic when it snows or rains.
  #4 (permalink)
Old 03-04-2008, 03:54 PM
krewat's Avatar
krewat has much to be proud ofkrewat has much to be proud ofkrewat has much to be proud ofkrewat has much to be proud ofkrewat has much to be proud ofkrewat has much to be proud ofkrewat has much to be proud ofkrewat has much to be proud ofkrewat has much to be proud of
You might have a cracked COP letting water in and shorting out, if it's that bad in the rain...
When it's misfiring, get the misfire counters in the PCM read to see which cylinder it is. If it's random, it's not a COP. If you see one cylinder doing all the misfires, change the COP on that cylinder.
The connector on the harness for the COP should have a rubber seal inside it like the fuel injectors and everything else does. Maybe the rubber is gone?
__________________
- art k. - Moderator for the Superduty, V10, and FE forums
'01 F250SD SC SB XLT V10 4x4 auto 3.73 Volant CAI, eBay headers and y-pipe
'97 Cougar XR7 30th Anniv Edition 4.6L
'74 F250 Highboy FE390 deceased!
I've been wrong before, I'll be wrong again. Just wait and see.
  #5 (permalink)
Old 03-04-2008, 11:00 PM
Silverdawg's Avatar
krewat,
Thanks for the suggestions. This has been an intermittent problem with the truck for a few years now. I've had it since 2004 and have replaced 3 COPS. None twice. It looks like there are only three OEM Motorcraft ones left, leading me to believe the prior owner had one go also.
It made it through a day of slogging it out in the rain without a hitch. Though I did make it a point to avoid puddles whenever possible. I didn't notice any cracks in the COPs when I had them out and the boots looked to be in good condition. I cleaned them up with a tacky rag and really scrutinized, so I would have noticed a crack. Then I put a ring of silicon grease around each boot near the tops. Blew the plug holes out with an air gun before reinserting the COPs. I'm going to get back in there tomorrow night and check out the seals on the connectors. Incidentally, I've noticed that a lot of the loom is loose and poorly taped. (I was squeezing water out of some of it just now). I know it all got undone when I had the heads replaced (under warranty for mis-manufactured leaky head gasket seats!!!) in 2006, so it looks like it got done sloppy. I guess it could provide places for wate to linger and drip and soak into old connectors.
If I start getting the misfires, I'll ask the tech for that information. But maybe I can lick this before it gets to that point.
While I'm at it though, I have a massive supply of split loom, 1/2 and 1/4 inch heat shrink and electrical tape. I think electric blue loom would look good.
The one thing I did want to rule out is water dripping on my PCM. I've heard something about leaky windshield gaskets or something. But I imagine the symptoms of that would be a bit more pronounced.
And galaxie641, thanks for answering my question. I'm still not sure about this whole distributorless ignition thing.
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is On
Trackbacks are On
Pingbacks are On
Refbacks are On
Powered by: vBulletin | Copyright ©2000 - 2008, Jelsoft Enterprises Ltd.
Ford-Trucks.com and Internet Brands, Inc. are not affiliated with the Ford Motor Company.
