Quote:
Originally Posted by Voh
I would say that i need somewhere around the 75" or so. It almost reaches to connect at both ends. I took the cable from the '73 doner truck, but the head end of it is very different on the newer generation. I was thinking that I might need to have one made.
1973 and later: The cable connects to the speedo head with a clip.
The pre 1973 cables screw on to the speedo head.
Look for one from 1967/72. C6's used the same cable 68/72 that '67's with COM did.
Don't limit your search to trucks, a car speedo cable will also work. Same ends, same trans and speedo head connections.
Example: C3DZ-17260-F .. Cable & Housing ~ 74 9/16" long.
Fits: 1963/65 Falcon with a 4 speed / 1964/66 T-Bird with COM / 1966 T-Bird with a C6.
