Go Back   Ford Truck Enthusiasts Forums > Older, Classic and Antique Trucks > 1961 - 1966 F-100 And Larger F-Series Trucks
Register - Join us, its Free! FAQ Members List Timeslips Calendar Mark Forums Read
1961 - 1966 F-100 And Larger F-Series Trucks Discuss the Slick Sixties Ford Truck
Is F-150 Still King?
LinkBack Thread Tools
  #1 (permalink)
Old 03-03-2008, 05:58 PM
Texas Monty is starting off with a positive reputation.
spray on bed liner
Anyone have any ideas or recommendations on spray on liners? I have a pretty scruffy bed - with alot of fender dents - banged out badly from the outside, and some rust holes in the floor and behind the cab. I was assured by a spray on bed vendor (of course) that he could patch those rust holes, and when that liner is on "you wouldn't see the dents."
but of course he WOULD say that - but I am intrigued. I use my bed for alot of hauling -this aint' no garage queen -and I would like a durable bed - easy to clean.
Monty
Sponsored Links
To remove this ad, register today!
  #2 (permalink)
Old 03-03-2008, 06:26 PM
jowilker has a very good reputation on FTE.jowilker has a very good reputation on FTE.jowilker has a very good reputation on FTE.
It is possible, bedliner will cover some minor dents and dings but not big ones. Your dealer can repair and cover, but you better be assured what is is from him before he starts. IMHO
John
__________________
In the cool still quiet hours of night, you can hear chevies rusting away.
  #3 (permalink)
Old 03-03-2008, 06:45 PM
bertha66's Avatar
bertha66 is starting off with a positive reputation.
When I had mine sprayed the first time I did not knock out all the dents, and they did show, evan some of the small ones. The first liner came off, cheap brand, so when I put on the new one, better brand, I did bang out the dents.
__________________
Allen D
1966 F-100 4x4 with 67 Fairlane GT 390 and Toyota power steering
1990 Areostar 2wd XLT ext
1991 Areostar 4wd XLT ext
1967 F-100 2wd with auto trans(now for parts)
1980 Bronco with 460
1968 F-350 exforest servive crew truck
1964 Galaxie 500 with 428
  #4 (permalink)
Old 03-03-2008, 07:49 PM
Customcab's Avatar
Customcab is starting off with a positive reputation.
I beleive as in all things prep work is a must. Even if your truck is use as a hualer; I recommend repairing the holes; I believe the spray guy will just patch the bottom of the hole with tape; spray and let dry; then you'll have a cover until something solid lands on it.
I would only recommend Speedliner for spraying; but linex & Rhino have warranties as well; just get it all clarified prior to paying. Speedliner has the best result's in my opinon; but its all in the prep work.
Getting most of the large dents and bumps straighten will allow future restoration if desired; so once a good quality spray liner is in its for good..
Mitch
__________________
Customcab 65 F100 SWB w/ 302cid & C6.
Future project:
78 F100 LWB 302cid & C6.
76 F100 LWB 300 & C4
64 F100 SWB 223 & 3spd
Family Issues
02 Explorer "Family Wagon"
99 Grand Prix GTP "Wifes Commuter"
96 Vulcan 1500
  #5 (permalink)
Old 03-03-2008, 08:59 PM
427SOHC's Avatar
427SOHC is starting off with a positive reputation.
I am planning on having the underside of my cab sprayed with rhino liner and was also thinking of having the inside of the firewall and inside floor board sprayed too.
I guy I know had the underside of the floorboard sprayed and it cut down the road noise.
  #6 (permalink)
Old 03-03-2008, 09:59 PM
paul 64 is starting off with a positive reputation.
I Would Repair All Dents And Rustholes And Prime Bed Pryor To Bedliner
It Wont Stop Rust Thats Already Eaing At The Metal Just Cover It Until Bottom Falls Out
  #7 (permalink)
Old 03-03-2008, 10:01 PM
FitchBanjos's Avatar
FitchBanjos is starting off with a positive reputation.
There is a pickup here in town that was completely coated in bed liner! Looks like hell but bullet proof.
__________________
Cliff Fitch
www.FitchBanjos.com
1966 F100 Custom Cab
  #8 (permalink)
Old 03-03-2008, 10:51 PM
hines182 is starting off with a positive reputation.
I haven't heard of or seen a Speedliner job but I've seen Rhino and Line-X. I chose Line-X on a newer pickup I had and I made the right choice. It held up wonderful and I thought it looked much better than a Rhino liner. I will definitely go Line-X for all my other rigs. I'm not sure if Speedliner is better, but you can't go wrong with Line-X and you won't regret it. As for prep. Definitely fix what you want fixed dent and hole wise yourself so they don't charge for bodywork, too. That's an easy way to cut down your final investment.
  #9 (permalink)
Old 03-04-2008, 12:46 AM
discochris's Avatar
discochris is starting off with a positive reputation.
Mine is Rhino lined, and I'm really happy with it.
  #10 (permalink)
Old 03-04-2008, 01:02 AM
gangstakr's Avatar
gangstakr is gaining momentum as a positive member of FTE.
A local company called TNT Bedliners sprayed mine pretty cool to watch it being done. But like everyone has stated, prep work is a must. Otherwise your just hiding the work you don't want to do. Rust won't go away, it's still doing damage much like a termite does, you can't see it happenning, but it is. Dent's won't magically disappear there still there and will show. Holes and othe damage areas will get taped then sprayed. So you want to fix this before you get it sprayed.
__________________
Staying low for now
64 lowered longbed
Robert
  #11 (permalink)
Old 03-04-2008, 10:47 PM
Pickupmanx2's Avatar
Pickupmanx2 is starting off with a positive reputation.
A bedliner is on my "to do list" for ALL of my trucks, I did a Line-X on my last 4 new trucks, definately a great addition, but I wouldn't cover up rust without first treating it really well. And yes dents WILL show, and it will still dent in but it does a nice job of protecting it, cleaning is easier, and crap doesn't slide all over. I am partial to Line-X, but again, prep-work is the key.
__________________
SEMPER FI
05 Lexus RX330
02 X Ultimate Limited/4x/7.3/5.5" Lift
77 F-150/4x/351M/4sp/SB
73 F-350 SCS/390/C6
66 F-250/4sp/300/6cyl/4bbl/Offy
63 F-250/4x/292/4sp/Flatbed
77 VW Conv
01 KTM 520 EXC
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is On
Trackbacks are On
Pingbacks are On
Refbacks are On
Powered by: vBulletin | Copyright ©2000 - 2008, Jelsoft Enterprises Ltd.
Ford-Trucks.com and Internet Brands, Inc. are not affiliated with the Ford Motor Company.
