Go Back   Ford Truck Enthusiasts Forums > Bronco > Big Bronco (1978 - 1996)
Register - Join us, its Free! FAQ Members List Timeslips Calendar Mark Forums Read
Is F-150 Still King?
LinkBack Thread Tools
  #1 (permalink)
Old 03-03-2008, 05:41 PM
mutang02 is starting off with a positive reputation.
truck died...help!!!
hey guys I have a 1988 bronco with a fuel inj 302. I was driving it down the freeway yesterday at about 70mph when the truck completely died. It was running fine until it just felt like someone turned the key off. I figure it is fuel pump related, but I have never heard of one just going out after running fine. I replaced both the fuel pump relay and the eec relay. I can start the truck with ether, so I figure it isnt the ignition. Also when you turn the key on the fuel pump never primes. Anyone know of anything else to check before replacing the pumps themselves. thanks
Sponsored Links
To remove this ad, register today!
  #2 (permalink)
Old 03-03-2008, 05:49 PM
NumberDummy's Avatar
Ford Parts Guru
NumberDummy has a spectacular reputation.NumberDummy has a spectacular reputation.NumberDummy has a spectacular reputation.NumberDummy has a spectacular reputation.NumberDummy has a spectacular reputation.NumberDummy has a spectacular reputation.NumberDummy has a spectacular reputation.NumberDummy has a spectacular reputation.NumberDummy has a spectacular reputation.NumberDummy has a spectacular reputation.NumberDummy has a spectacular reputation.
Quote:
Usual cause: Ignition module and/or stator (aka pickup coil) inside the dizzy.
Where is the module, on the dizzy or on the left fender inner apron (prolly on the dizzy)? Ford used both types, depending on the engine size.
If on the dizzy, you'll need a thin shanked TORX driver to remove it.
Dizzy Module: E43Z-12A297-A (Motorcraft DY-425) Marked: E3EF-12A297-A1A or A2A.
E5PZ-12A112-A .. Stator (Motorcraft DU-30-A)
__________________
Bill / Retired Ford Parts Manager ~ 1962/1997
Part Number Research: Trucks: 1928/2002 / Cars: 1928/2003
1963 Galaxie 500XL / 1965 F100 / 2008 Fusion S / 2008 Edge SEL
  #3 (permalink)
Old 03-03-2008, 06:03 PM
the ignition module would cause the fuel pump not to prime? is there a way to test the module before replacing it? I am trying to spend as little money as possible, I close on my first house friday, and will be eating nothing but ramen as it is. thanks
  #4 (permalink)
Old 03-03-2008, 06:16 PM
andym's Avatar
andym has much to be proud ofandym has much to be proud ofandym has much to be proud ofandym has much to be proud ofandym has much to be proud ofandym has much to be proud ofandym has much to be proud ofandym has much to be proud ofandym has much to be proud of
If the ECM doesn't think the distributor is turning (the hall effect sensor inside the distributor tells it so) then it won't turn the fuel pump on.
So yes, it can cause this. Also if the ECM itself died it will cause this behavior. Can you pull codes from it? If so, the ECM is probably ok.
You could also have a wiring problem somewhere between the relay and the pump.
__________________
Andy
1989 F-150 XLT Lariat Shortbed 4x4 300/T-18/3.55
1990 Bronco Eddie Bauer 4x4 351/E4OD/3.55
Quote:
It often takes more courage to change your opinion than to stick to it.
Election 2008 results: World's worst job given to a black man.
  #5 (permalink)
Old 03-03-2008, 06:43 PM
but the pump should prime when you turn the key on before the engine starts rolling over.....before the distributor turns correct?
  #6 (permalink)
Old 03-03-2008, 06:56 PM
andym's Avatar
You know what... you're right. I must be asleep over here.
It's either a dead pump (a multimeter at the pump will tell that for sure), a wiring problem (open circuit, loose ground) or a dead ECM.
__________________
Andy
  #7 (permalink)
Old 03-03-2008, 07:05 PM
thats cool I was just making sure I am not crazy. can i just unhook the wires from the pump, and see if they are getting juice with the key on? or does it only send juice for a second until you start to try to roll the engine over? also the truck also has what looks to be a second pump on the framerail....is that stock?
  #8 (permalink)
Old 03-03-2008, 07:10 PM
blue beast's Avatar
blue beast is gaining momentum as a positive member of FTE.blue beast is gaining momentum as a positive member of FTE.
I had a wire get worn through on mine, The wire bundle was touching the alt bracket
and it was a bear to find since I had to pull apart the loom and undo all the tape
and finally I found it. So bust out the multimeter and a safety pin and trace the wire
for the fuel pump start at the pump itself and stick the pin in every 12 inches until
you get voltage. You can also just inspect all the wiring where it comes into contact with any metal part. Don't just start throwing parts at it get a DVOMeter and test
test test tell us what you get and we can give you other stuff to test. Unless you
like wasting money.
__________________
86 fs bronco 302 auto 33x12.50 at rusty but trusty!
04 Ranger edge 3.0 5 speed auto 4.10
Before posting fuel related problems Run a couple of bottles of dedicated gas line dryer through IT!!!!!!!
There now I don't have to say it every time!!!!
  #9 (permalink)
andym's Avatar
Yes that's how you can test to see if the pump is getting power.
That is a stock setup. For EFI trucks up until 1990, there was an external high pressure pump on the driver's side frame rail roughly under the front seat and a low pressure pump in each tank. In 1990 they went to a high pressure pump in the tank.
__________________
Andy
  #10 (permalink)
Old 03-03-2008, 08:25 PM
alright I will do that after work tommorrow thanks a ton guys
  #11 (permalink)
Old 03-03-2008, 08:45 PM
Encho's Avatar
Encho is starting off with a positive reputation.
Before anything else, check the fuse box (manual in hand), it might be something as simple as that.
__________________
Cherokees make such beautiful trailers
Member of the International Chapter
  #12 (permalink)
Old 03-03-2008, 09:37 PM
i already checked every fuse just to be sure, It actually ran good enough off ether to load it on the trailor, granted it took 3 cans......
  #13 (permalink)
Old 03-03-2008, 10:48 PM
Bimmerboy1989 is starting off with a positive reputation.
The ECM is turning on I assume? The ECM relay controls the ground to the fuel pump relay. If the ECM relay doesn't come on the fuel pump doesn't come on. How about a faulty inertia switch?
  #14 (permalink)
Old 03-03-2008, 11:52 PM
blue beast's Avatar
Don't waste your money on Ether(not really ether anymore!!) Just use a propane
torch (not lit) and run it off that. You can start it, diagnose vac leaks, loosen seized
hardware and burn the sucker to the ground if it makes you that mad!! All with propane
If the inertia switch is faulty please don't just wire around it!! At least put a toggle
and mark it FUEL PUMP in big letters so if you wreck out and a flame thrower is issuing
from your grill they will know to cut that switch!!
__________________
  #15 (permalink)
Old 03-04-2008, 06:18 PM
alright guys, checked the wiring going into both pumps, and there is no juice at either one. however there is juice coming out of both the fuel pump relay and eec relay. There are four wires coming out of each relay and three of the four on both are hot. does that leave me with a possible bad wire somewhere? Could it still be the inertia switch? and if so where is it located?
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is On
Trackbacks are On
Pingbacks are On
Refbacks are On
Powered by: vBulletin | Copyright ©2000 - 2008, Jelsoft Enterprises Ltd.
Ford-Trucks.com and Internet Brands, Inc. are not affiliated with the Ford Motor Company.
