Okay...couple of quick questions...
Local Ford stealership told me it was #E8TZ-1109-A and discontinued (obsolete)
The rear end is not a disc but a drum. I have no problem getting a rotor for it if the hub fits...Is your number still available (Not obsolete)?
Lastly, the question primarily here is does anyone recognize this application since the spindle is 2.5" vs the normal 2.1",can I find a rear hub for this and does someone has a source?
at this point, I would take anything I can get but it's such an oddball there are none up here. If it was available from Ford, I would be happy to order one...is the new style with the rotor compatible with the drum style?
You would need a housing from a drum brake Dana 70.
Also, don't limit your search to Fords. Dodges and Chevies used Dana 70's as well. Be careful of bolt pattern though. I know Dodges are the same, but not sure on the HD Chevy stuff.
What's wrong with the one you have? Just that piece of metal chipped off the one side?
I just saw this post. If you have any doubt about the model of the axle, don't buy anything for it until you find out what it is. It could also be a Dana 80. Is there a BOM anywhere on this axle?
You didn't specify front or rear, you just said hub and showed a picture.
I haven't seen one of these hubs in person since 1997, the year I retired.
There are two different rear hubs with a Sterling 10.25...with or without dual rear wheels.
Thanks...the rear end is definately a Ford Dana 70 HD...the BOM Is extemely worn but the numbers appear to be the ones I listed. The problem with this hub is nothing...I am missing the other one (Only have one which makes going down the road challanging)!!!
