Head oil drain ??
Head oil drain ??
I was changing my injectors and knocked a push rod out of its holder while prying on injector. When I was attempting to put it back, the little ball fell out of the bridge or rocker arm mechanism. It went to the bottom of the head. I tried to grab it with a magnet but pushed it unknowingly into the oil drain hole for the head. Would my chrome ball be in the oil pan now or stuck in the oil passage somewhere? I can't see it and a magnet doesn't retrieve anything.
Thanks
Kelly
Thanks
Kelly
I went fishing the last 2 nights have come up empty. I ordered the rocker arm (that is how you get the ball we think). I need to blow air through that hole to check for restrictions. I drained the oil, swept the pan with a magnet, opened up the dipstick hole to get a magnet in with nothing ever showing up on the magnet. Drain hole is too small to get much going into the pan but I used a strong magnet on the bottom and moved it to the drain many times but never got anything. Maybe I should attach one of those little strong magnets to bottom of pan and leave it there. At this point, i am going to leave it in there.
