Guys who set the 351w timing to 14 BTDC.... - Ford Truck Enthusiasts Forums
Old 03-03-2008, 12:51 PM
78bigunns's Avatar
78bigunns 78bigunns is offline
78bigunns is starting off with a positive reputation.
Why did you do it? Is there a small gain somewhere?
I noticed it in some sigs, and thought there was some info on thread somewhere, but my searches show more generic stuff about timing setups.
If this is something that will even in the slightest improve a regular trucks performance, I'd like to know, and also how to set it on these trucks with the "spout".
Only timing I've ever done was on a 460/carbed, and a 352/carbed.
Thanks for any insight or explanations.
Blair
Old 03-03-2008, 01:44 PM
Conanski's Avatar
Conanski Conanski is offline
Conanski has much to be proud ofConanski has much to be proud ofConanski has much to be proud ofConanski has much to be proud ofConanski has much to be proud ofConanski has much to be proud ofConanski has much to be proud ofConanski has much to be proud ofConanski has much to be proud ofConanski has much to be proud of
Setting base timing is the same on the '87-97 EFI trucks as it is on the earlier carb'd motors, turning the distributor clockwise advances the base timing, and this must be done with the spout removed on the EFI motors. Advancing the timing from the factory setting of 10deg BTDC will produce more TQ and HP, but it will also make a motor more detonation prone. You should not just set it where somebody else has, every motor is different and it's sensitivity to detonation will be different, so adjust it to whatever the motor will tolerate. How do you know how much? Start with 2 degrees additional advance, and then take it for a drive and try to load the motor and listen for pinging or hesitation. At hwy speeds in OD under part throttle(just before the tranny downshifts for an auto) in hot weather will be highest load. If it's OK with 12degrees, bump it couple more and test again. Once you make it ping you want to back it off to the previous setting.
Old 03-03-2008, 02:33 PM
78bigunns's Avatar
Thanks for the explanation Paul. I have completely grasped the concept.
I'll see what gives maybe one night this week.
Is there a accurate way to describe the detonation, the way it sounds?
I'm sure I've heard it, but wouldn't have known what I was listening to, so I may not have realized it was confirmed detonation.
I guess I can tinker and roll out, see how it goes.
Thanks again.
Blair
Old 03-03-2008, 09:57 PM
baddad457 baddad457 is offline
baddad457 has a very good reputation on FTE.baddad457 has a very good reputation on FTE.baddad457 has a very good reputation on FTE.
Ping is what we used to call "Valve clatter". To gain more advantage from advancing the timing, you can upgrade to a higher octane fuel. Bump the timing till it pings, then try more octane and see what the motor likes. Your mileage will likely improve too, offsetting the cost of the higher octane fuel.
Old 03-04-2008, 09:29 AM
Conanski's Avatar
Yeah.. pinging sounds like a rattle or clatter, some people say it sounds like shaking marbles in a can. It won't be really loud so you'll have to shut off all noise generating devices and listen carefully.
Old 03-04-2008, 02:53 PM
78bigunns's Avatar
Cool, hope to poke at her tomorrow and tinker with it.
Let you know how it goes.
Old 09-22-2016, 03:59 PM
zarmo zarmo is offline
zarmo is starting off with a positive reputation.
okay a stupid question. so when you set your new timing and road test for ping, do you I assume put in the spout before you go out for the road test? I would think so, but you did not say, so someone might leave it out and road test till it pings then put in the spout and really have a pining problem.
Old 09-22-2016, 08:36 PM
yea, reinstall the spout connector once you set the timing
Old 09-22-2016, 08:38 PM
Conanski's Avatar
Yes the spout plug must go back in after setting the base timing, otherwise the motor will not see it's regular timing advance and will be way down on power.
No Acceleration captanron 1980 - 1986 Bullnose F100, F150 & Larger F-Series Trucks 5 06-18-2016 12:46 AM
Distibutor/Timing problems???:( JaceNeal1996 1967 - 1972 F-100 & Larger F-Series Trucks 9 08-28-2013 11:17 AM
Straight-up Timing Set - Which one? quakerj 1980 - 1986 Bullnose F100, F150 & Larger F-Series Trucks 1 07-26-2013 07:02 AM
gas shooting up out of carb logan.hawes FE & FT Big Block V8 (332, 352, 360, 390, 406, 410, 427, 428) 12 09-19-2011 02:03 PM
A few questions about installing Edelbrock carburetor jaspirr 1973 - 1979 F-100 & Larger F-Series Trucks 4 04-18-2010 02:07 PM
Tags
14, 1977, 1990, 1992, 351, 351w, 50, adjust, btdc, built, degrees, f150, ford, noise, pinging, set, tdc, timing, truck
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
