How to check for a vacuum leak? - Ford Truck Enthusiasts Forums
Old 03-03-2008, 12:04 PM
Big_Man_Brad Big_Man_Brad is offline
Big_Man_Brad is starting off with a positive reputation.
Ok so i'm pretty sure the more people i talk to and the more i really think about it that i have a vacuum leak somewhere..I hear that poor mileage can come form a vacuum leak..When i first but in my vacuum gauge i had 21.5 vacum..And on my way home yesterday idling in my driveway i had 18..I sprayed starting fluid all under my hood and found no idle pick up...How do i go about finding a vacuum leak???Also as soon as i start my truck should i have maxium vacuum or will it take 5 or 10 minutes..Any help would be greatly appreciated..
Thanks
Old 03-03-2008, 03:04 PM
Conanski's Avatar
Conanski Conanski is offline
Conanski has much to be proud ofConanski has much to be proud ofConanski has much to be proud ofConanski has much to be proud ofConanski has much to be proud ofConanski has much to be proud ofConanski has much to be proud ofConanski has much to be proud ofConanski has much to be proud ofConanski has much to be proud of
Quote:
Vacuum should be generated instantly I would think. Did you check the brake booster and the vacuum resovoirs for leaks? You can isolate there items by disconnecting the vacuum lines that feed them and plugging them temporarilly while you monitor the vacuum signal on a gauge. You might want to try using an unlit propane torch to find a potential leak, a gas will get pulled in easier than a liquid.
Old 03-03-2008, 03:47 PM
Ok i'm going to go do the brake booster thing right now!!!
Old 03-03-2008, 05:07 PM
Ok i did that and i had no success..But i got a code reader and pickup a code..It was number 33..I read on fordfuelinjection.com that it has something to do with the egr..Could this have something to do with my vacuum problem and poor fuel economy.
Old 03-03-2008, 05:13 PM
andym's Avatar
andym andym is offline
andym has a superb reputationandym has a superb reputationandym has a superb reputationandym has a superb reputationandym has a superb reputationandym has a superb reputationandym has a superb reputationandym has a superb reputationandym has a superb reputationandym has a superb reputationandym has a superb reputation
Yes it could. I would start troubleshooting that code. Test the EGR valve, the EVP, etc.
As far as detecting a leak, it should hold vacuum after you shut the engine off. If the vacuum disappears, then you have a leak somewhere.
Old 03-03-2008, 05:43 PM
EPNCSU2006's Avatar
EPNCSU2006 EPNCSU2006 is offline
EPNCSU2006 has a very good reputation on FTE.EPNCSU2006 has a very good reputation on FTE.EPNCSU2006 has a very good reputation on FTE.EPNCSU2006 has a very good reputation on FTE.
It won't hold manifold vacuum after shutdown, but it should hold in the reservoir(s). The best way to find a vacuum leak is with a smoke test where smoke is pumped into the manifold (engine off of course) and then it's just a matter of finding where the smoke is coming out to find the leak. However, that's not something an average do-it-yourself driveway mechanic would be able to do. Have you checked ignition timing? Ignition timing can influence both manifold vacuum readings and fuel economy (power too, of course), so if it isn't correct that could be another possibility.
Old 03-03-2008, 08:45 PM
The only recent thing i have done to it lately is the performance throttle body and i got the tps set at the right volts..This one might be over my head i might have to take it in..
Old 03-04-2008, 08:53 AM
Conanski's Avatar
Do you have metal juice can vacuum resovoirs on this truck, or the plastic versions? If metal I'll bet $$ they are rusted out on the bottom.
Old 03-04-2008, 09:08 AM
I'm pretty sure there plastic but i'll check...
Old 03-04-2008, 04:10 PM
guitarnik's Avatar
guitarnik guitarnik is offline
guitarnik is starting off with a positive reputation.
i think i have a vacuum leak but do not know how to test the pressure. some help please.
Old 03-04-2008, 07:19 PM
Yep they are plastic...Since my dad was home today he said he would help me..So my dad said that maybe my timing should be increased and first we did it by ear and he said it sounded the best then we did it with the light so now it's set at 17 degrees..He also told me that i got a miss..So we checked all the wires and they were good..I think its the passenger back cylinder..After work he said that were going to do a compression test..I hope everything goes ok...
Old 03-04-2008, 07:23 PM
Virto's Avatar
Virto Virto is offline
Virto has a good reputation on FTE.Virto has a good reputation on FTE.Virto has a good reputation on FTE.
On the 460, does the PCV valve dump into number 8 like on the 302?
If that is the case, it's pretty common to run into issues with the number 8 cylinder (rear passenger side) in high mileage motors.
Let us know the compression numbers.
Old 03-04-2008, 07:40 PM
Hmm i'm not sure on that one...I'll let you know though...
Old 03-06-2008, 12:06 PM
The compression is super the guy said..I don't remember the numbers right now..Than we hooked it up to his computer...Got not one single code..I was bumbed...He said my problem could be that the intake manifold where it hooks up to the throttle body its stightly bigger the throttle body for the mileage loss...And for the vacuum its where its suppose to be..He had no idea how i was getting 21.5 vacuum before...
Old 01-03-2010, 07:44 PM
rick_76 rick_76 is offline
rick_76 is starting off with a positive reputation.
83 f100 4.9 6 cyl
I recently changed the intake manifold because it was leaking. I rebuild the carborator and it seems like I have a vacuum leak somewhere. I checked the compression on number 6 and I'm getting 95 psi and the rest are between 130-150 psi.
Does anyone know how I can fix this leak...?
Everything You Wanted To Know About The IWE System...And Then Some xjcamaro89 2004 - 2008 F150 404 01-03-2017 01:59 PM
Determining Vacuum Leak on 1998 Expedition 5.4L mikulskn Expedition & Navigator 16 12-30-2014 01:21 PM
Holley 4160 won't idle below 900 wyckedcombo17 1973 - 1979 F-100 & Larger F-Series Trucks 11 08-15-2014 07:25 AM
Ported Vacuum, how it changes with throttle/rpm 1975FordF250 FE & FT Big Block V8 (332, 352, 360, 390, 406, 410, 427, 428) 3 06-24-2014 10:06 PM
Vacuum Leak tatonka 1987 - 1996 F150 & Larger F-Series Trucks 3 01-21-2014 07:14 PM
Tags
150, 98, booster, brake, check, checking, f150, f250, ford, leak, leaks, search, truck, vacrum, vacuum
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Forum Jump
