Go Back   Ford Truck Enthusiasts Forums > Other Fords > 1968 - Present Full Size Vans
Register - Join us, its Free! FAQ Members List Timeslips Calendar Mark Forums Read
Is F-150 Still King?
LinkBack Thread Tools
  #1 (permalink)
Old 03-03-2008, 11:07 AM
jcbx is starting off with a positive reputation.
STEERING STABILIZERS on E-line ..... anyone recommending that ?
http://info.rockauto.com/Monroe/Deta...tNumber=SA1930
anyone that is using something like this ?
is it usefull or just a waist of money ?
and if anygood what did it do for you excactly ?
Sincerly
JCBX
Sponsored Links
To remove this ad, register today!
  #2 (permalink)
Old 03-03-2008, 11:37 AM
YoGeorge is gaining momentum as a positive member of FTE.YoGeorge is gaining momentum as a positive member of FTE.
It's a shock absorber....
Quote:
Originally Posted by jcbx
http://info.rockauto.com/Monroe/Detail.html?http://catalog.tenneco.com/monroe/partImageDisplay.do?partNumber=SA1930
Sincerly
JCBX
...that keeps the front wheels from wobbling (or steering) without some resistance. They are most often used by off-roaders, to avoid "kick back" thru the steering when you hit a rock or something.
One of these might also "mask" worn front end parts a bit, by keeping the front wheels from "shimmying" if there is some play in the steering mechanism, but the play will still be there when you turn the wheel. If you have worn front end parts, they should be replaced in any case and with power steering on the van, that should be preventing most kickback anyway unless you're off-roading. And because it will make the front wheels resist turning, may wear out front end parts faster.
I put a stabilizer on an old 1980 FJ40 Toyota Land Cruiser which had no power steering. My upper body was in GREAT shape while I had that thing, and I'd dread parallel parking with it....
George
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is On
Trackbacks are On
Pingbacks are On
Refbacks are On
Powered by: vBulletin | Copyright ©2000 - 2008, Jelsoft Enterprises Ltd.
Ford-Trucks.com and Internet Brands, Inc. are not affiliated with the Ford Motor Company.
