Locked converter
03-04-2008, 08:27 PM
on
I'll give it a go. Might be tomorrow before I get to it. More to come.........
03-04-2008, 09:32 PM
on
Ok so I tried it tonight. It shows as Pass on the scanner so either everything tests ok or the scanner won't read the diesel.
03-05-2008, 07:50 AM
on
Stalls in Man1 and R?
If stalling in all selected gears with no codes would lead me to a hydraulic or mechanical failure. I would check line pressure first. Trans warm in park should be 50 to 65 psi. If pressure is good remove the P/Y wire off the s-pack connector and retest the gears for lockup.
Could be one of a few issues.
Bill
03-07-2008, 08:08 PM
on
Success!!
I changed the converter and was definitely the problem. I cut the old one apart and there was nothing in there but shrapnel.
Now I need to do a full fluid and filter change. Anyone know how much oil it takes?
03-07-2008, 08:17 PM
if the converter is drained and the filter is changed it will be 14-17 quarts.
03-07-2008, 08:19 PM
16qts. glad you fix her!
kurt
03-07-2008, 08:35 PM
on
Thanks guys. I'm sure I'll be back with more questions.
03-07-2008, 09:21 PM
on
Glad to here!!!
My WAG was going to be TC or bad valve in the pump.
Did you pull the pump?
Bill
03-08-2008, 06:36 AM
on
No I didn't pull the pump. I just pulled the tc, blew out any openings and put in the new one.
03-08-2008, 07:35 AM
on
Back flush the cooler.
Most of the material from the TC can be in the cooler.
Bill
03-08-2008, 08:31 AM
Hey I also just remembered I think you have a 2wd truck. It will take a few less quarts of oil than I told you earlier. they have a smaller trans pan.
