Go Back   Ford Truck Enthusiasts Forums > Older, Classic and Antique Trucks > 1961 - 1966 F-100 And Larger F-Series Trucks
Register - Join us, its Free! FAQ Members List Timeslips Calendar Mark Forums Read
1961 - 1966 F-100 And Larger F-Series Trucks Discuss the Slick Sixties Ford Truck
Is F-150 Still King?
LinkBack Thread Tools
  #1 (permalink)
Old 03-03-2008, 07:37 AM
White97 is starting off with a positive reputation.
Would this 4spd fit?
local seller has :
65 FORD SMALL TEN SPLINE COMPLETE WITH ORIGINAL SHIFTER AND LINKAGE INTACT LONG TAIL TAG NO. HEH-J 012246 Out of a Galaxy. He wants $300.
Would this fit behind my FE? Not sure yet if block is 352 or 390. I'm still in parts gathering mode, block will be yanked in the spring. Based on the only casting number Bill identified the block as a passenger big block.
Thanks
__________________
Lou
1965 2wd F100 - 352 Short Styleside
1997 Explorer XLT 302
2008 Hyundai Santa Fe Limited
Sponsored Links
To remove this ad, register today!
  #2 (permalink)
Old 03-03-2008, 07:45 AM
NumberDummy's Avatar
Ford Parts Guru
NumberDummy has a spectacular reputation.NumberDummy has a spectacular reputation.NumberDummy has a spectacular reputation.NumberDummy has a spectacular reputation.NumberDummy has a spectacular reputation.NumberDummy has a spectacular reputation.NumberDummy has a spectacular reputation.NumberDummy has a spectacular reputation.NumberDummy has a spectacular reputation.NumberDummy has a spectacular reputation.NumberDummy has a spectacular reputation.
Quote:
Originally Posted by White97
local seller has :
Thanks
A 352 in a car or truck is the exact same engine, ditto for a 390.
The exhaust manifolds, oil pan and pickup tube and the motor mounts are different, but those are bolt on items...the block/heads/intake manifold/waterpump/starter/carb/dizzy, etc = identical.
HEH-J / Ford 4 Speed Top Loader / 1965 Galaxie 390.
Will it bolt up to a 352?
Yes, but you're going to have to change the shift linkage, or change to bucket seats.
Otherwise, the shift lever will be under your present bench seat...kinda difficult to shift it that-away.
THE PRICE IS A STEAL!!
If you snooze, you lose! Buy that puppy!!
__________________
Bill / Retired Ford Parts Manager ~ 1962/1997
Part Number Research: Trucks: 1928/2002 / Cars: 1928/2003
1963 Galaxie 500XL / 1965 F100 / 2008 Fusion S / 2008 Edge SEL
  #3 (permalink)
Old 03-03-2008, 08:53 AM
Thanks Bill - I just got it. Picking it up tomorrow night. He said the shifter is on the side and should come up in the correct location. If not I'll modify, I really want to keep the bench seat.
__________________
Lou
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is On
Trackbacks are On
Pingbacks are On
Refbacks are On
Powered by: vBulletin | Copyright ©2000 - 2008, Jelsoft Enterprises Ltd.
Ford-Trucks.com and Internet Brands, Inc. are not affiliated with the Ford Motor Company.
