Go Back   Ford Truck Enthusiasts Forums > Misc. > Fuel Injection, Carburetion & Fuel System
Sign in using an external account
Register Forgot Password?
Register - Join us, its Free! Albums FAQ Members Tech Guides Search Today's Posts Mark Forums Read VendorsUsed CarsGarage
Welcome to Ford Truck Enthusiasts Forums
  #1 (permalink)
Old 03-02-2008, 10:49 PM
muscletruck7379's Avatar
muscletruck7379 muscletruck7379 is offline
1984 Ford Bronco
muscletruck7379 has a good reputation on FTE.muscletruck7379 has a good reputation on FTE.
what is the proper way to adjust idle speed?
i have an 88 f150 with the 5.0. i am under the understanding that with the IAC disconnected, the engine should still idle at 750 rpm. to make a long story short, mine doesn't, but if i run the screw in with the iac disconnected, when i recconect it, it idles above 1300rpm. i did this once on my ranger, but i must be missing a bit of that memory.
__________________
1973 f250 highboy 4x4
1984 full size bronco, -DIS, wide band megasquirted 300 and np435 w/ dual range aux tranny on the way! - finally updated! 12/29/2011
1988 f150 extended cab 4x4, mostly stock.
1984 mercury capri, 5.0 conversion, my little monster...
1961 ford falcon, all stock, in family since '68
  #2 (permalink)
Old 03-03-2008, 12:07 PM
jb1390 jb1390 is offline
Garage is empty, add now
jb1390 is starting off with a positive reputation.
I believe that if you disconnect the iac, it will stay in whatever position it was when it was unplugged. Out of curiosity, why do you want the iac disconnected?
  #3 (permalink)
Old 03-05-2008, 01:34 AM
mauicruza's Avatar
mauicruza mauicruza is offline
mauicruza is starting off with a positive reputation.
I've been told to set idle with IAC disconnected and all your accs on e.g. lights, a/c blower. You also need to adjust your TPS accordingly to your vehicle specs so your ECM knows where idle is.
  #4 (permalink)
Old 03-06-2008, 07:07 PM
blue beast's Avatar
blue beast blue beast is offline
blue beast is gaining momentum as a positive member of FTE.blue beast is gaining momentum as a positive member of FTE.
It should be at about 600 rpm no IAC connected and the spout disconnected.
I would start with the timing and get that set correctly that way it isn't messing
with the idle quality. Of course to set the timing you need to unplug the spout
connector and set it to the underhood sticker, I always check the where the timing
is before adjusting it with the spout and w/o spout and compare it to after. Then
unplug the IAC and spout and start it up, adjust the screw to about 800 rpm then back it down to 600 rpm or even 550 then turn it off and press the pedal to the floor
a couple times and restart the truck and see it didn't drift, kill it and hook up all the
connectors and restart it should be idling at 750rpm with nothing on and it should
bump up when the lights, ac etc are on. The area where the screw rides can get
worn out and then the idle drifts to a lower setting not to mention vibration backing
it out over time. a dab of blue locktite or super glue on the side of the screw to prevent it from backing out once you get it set. Don't put it on the screw so it locks the screw and
you will need a torch to loosen it next time
__________________
86 fs bronco 302 auto 33x12.50 at rusty but trusty!
91 ford probe lx mtx The mighty vulcan 3.0
Before posting fuel related problems Run a couple of bottles of dedicated gas line dryer through IT!!
  #5 (permalink)
Old 03-24-2008, 11:35 AM
1991 ford f-250 1991 ford f-250 is offline
1991 ford f-250 is starting off with a positive reputation.
i dont mean to steal away from your question, but just to add onto it..
What sensors, if any, have anything to do with idle speed?
  #6 (permalink)
Old 05-12-2008, 12:51 AM
1984 Ford Bronco
idle air control motor (iac) for the most part, but also: the throttle position sensor (tps) and air conditioner being on/off can affect it.
__________________
Tags
1984, 1991, 1999, 2004, 30, 50, 86, adjust, f150, ford, idle, liter, mercury, problem, proper, ranger, speed
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is On
Trackbacks are On
Pingbacks are On
Refbacks are On
Forum Jump
Powered by vBulletin® Version 3.7.5
Copyright ©2000 - 2013, Jelsoft Enterprises Ltd.
SEO by vBSEO 3.5.2 ©2010, Crawlability, Inc.
vbulletin Admin Backup
