86 F-250 Front caliper removal
I have a 86 f-250 and the front caliper ( dual piston- 8600 gvw). All the ford brakes I have done in the past have a 1/2" or 9/16" headed bolt holding in a H-clip and spring in the bottom. This truck does not have the bolt or h-clip. It looks as if the caliper only comes off when removed with the rotor.
Does this make any sense?
__________________
'65 F-250 4x4 w/ '76 460 & 514 in a 1900lb Drag Rail
Under construction: "Black & Bad" '79 F-150 4x4 -351w, 435np, 205np, TFS Twisted Wedge heads, Speed demon, Comp 4x4 extreme cam, edelbrock RPM AirGap, NOS Powershot, detriot locker, w/a '73 grille
