Go Back   Ford Truck Enthusiasts Forums > Other Fords > 1968 - Present Full Size Vans
Register - Join us, its Free! FAQ Members List Timeslips Calendar Mark Forums Read
Is F-150 Still King?
LinkBack Thread Tools
  #1 (permalink)
Old 03-02-2008, 10:52 PM
icuhatn99 is starting off with a positive reputation.
Something burning?? Not a good smell
I was trying to turn over the ignition on my 74 e-100 and all of the sudden smelled/saw smoke coming out of the hood/dash area..after the smoke cleared I opened the hood and noticed it was coming roughly from the area where the ignition module and starter solenoid are,but could'nt pin point exactly where....now when I turn the ignition....nothing..not even a click....I am thinking either starter solenoid or ignition module??? anyone ever had either of these fry like that....I also noticed the previous owner had the battery cables on really loose..so maybe a bad ground or ??? caused the meltdown....
Sponsored Links
To remove this ad, register today!
  #2 (permalink)
Old 03-05-2008, 05:13 PM
jevfro is starting off with a positive reputation.
Yea I'd check the starter solenoid and all the connections. I burnt one up on my 78 F150 by cranking it too long w/ some bad connections to boot. Check battery cables and ground connections are tight and clean too.
  #3 (permalink)
Old 03-05-2008, 06:28 PM
mhg mhg is offline
mhg is starting off with a positive reputation.
do you have any lights or radio
if not there are several fusible links inside the wire harness
this may be your problem also
__________________
2003 bull 3.0 24v stock
1996 E-350 351
  #4 (permalink)
Old 03-05-2008, 10:02 PM
Yeah, I think it might be the fusible link that connects to the starter solenoid,it says 16ga fusible link on it and it feels really flexible like the wire inside burnt up....going to check tomorrow ..also bought all new battery cables,ignition starter switch and starter solenoid
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is On
Trackbacks are On
Pingbacks are On
Refbacks are On
Powered by: vBulletin | Copyright ©2000 - 2008, Jelsoft Enterprises Ltd.
Ford-Trucks.com and Internet Brands, Inc. are not affiliated with the Ford Motor Company.
