Go Back   Ford Truck Enthusiasts Forums > Performance, Engines and Troubleshooting > Y-Block V8 (239, 272, 292, 312, 317, 341, 368)
Register - Join us, its Free! FAQ Members List Timeslips Calendar Mark Forums Read
Is F-150 Still King?
LinkBack Thread Tools
  #1 (permalink)
Old 03-02-2008, 10:40 PM
61Rat is starting off with a positive reputation.
Talking 292 Bellhousing Question
Hey guys, I've been lurking here for a couple of months but this is my first post. I've got a '61 Unibody Shorty that had a 223 from the factory and I found a 292 today for it. It will be a mild custom/hot rod and I want to keep my Three on the Tree so my question is will the 223 bellhousing and trans work on the 292? Any help would be appreciated. Thanks!
Sponsored Links
To remove this ad, register today!
  #2 (permalink)
Old 03-03-2008, 11:18 AM
bigwin56f100's Avatar
bigwin56f100 is starting off with a positive reputation.
You will need a 292 bell housing from a 57 and newer truck. The 54-56 truck bell housings do not have the provision for the clutch bell crank to bolt to it. You will also need the bell housing from a three speed as the 4 speeds are different too.
Your trans will fit up with no problems.
Kevin Bigwin
__________________
1956 Custom Cab Big Window. 272 Y block 3sp. See gallery. Kevin
  #3 (permalink)
Old 03-03-2008, 05:46 PM
Thanks, Kevin. The engine I just bought has a 4-speed bell. Anyone got a 3-speed b/h or need a 4-speed b/h? Let me know, I don't need the 4-speed.- Mark
  #4 (permalink)
Old 03-03-2008, 08:59 PM
Tom Dowdell is starting off with a positive reputation.
Check to see if you need a front cross member for a V-8 truck, on my 55 truck the 6 cyl. was longer and rested on the front frame. I had get another another cross member for the front motor mount when I switched to a V-8. If the engine came out of a car you made need a different timing chane cover and motor mount for the truck?
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is On
Trackbacks are On
Pingbacks are On
Refbacks are On
Powered by: vBulletin | Copyright ©2000 - 2008, Jelsoft Enterprises Ltd.
Ford-Trucks.com and Internet Brands, Inc. are not affiliated with the Ford Motor Company.
