Life Span of OEM shocks? - Ford Truck Enthusiasts Forums
1999 to 2016 Super Duty 1999 to 2016 Ford F250, F350, F450 and F550 Super Duty with diesel V8 and gas V8 and V10 engines
Old 03-02-2008, 09:20 PM
sportscar's Avatar
sportscar sportscar is offline
sportscar is starting off with a positive reputation.
Truck is 4 years old with 33,000 miles, but feels bouncy over the potholes. Shocks gone? F250 4x4 with stock shocks (non F4X)
Old 03-03-2008, 05:29 AM
rmosso1 rmosso1 is offline
rmosso1 has a good reputation on FTE.rmosso1 has a good reputation on FTE.
My F-350 F x 4 with 6.0 lasted about 25,000 mi and then I had the notorious death wobble. Yours probably last longer as your V-10 engine weighs less. When you replace the shocks, if you get someone to do it, look at your old shocks. Mine could be moved in and out with little effort. I replaced all five and the truck rode better than when it was new.
Old 03-03-2008, 06:31 AM
350z 350z is offline
350z is starting off with a positive reputation.
Thumbs up
I just installed 4 bilstein 5100 series shocks at 25k , 3 of the four fx4 shocks were bad , they didn't have any gas in them , made a huge difference !
Old 03-03-2008, 06:58 AM
ffadragon ffadragon is offline
ffadragon is starting off with a positive reputation.
Replace immediately with 4 new Bilstiens!!!
You won't regret it.
Front Shock Travel length? Metal twister 1999 - 2003 7.3L Power Stroke Diesel 5 02-05-2017 12:11 PM
Will F250 shocks work? hwybee22 Excursion - King of SUVs 3 11-23-2016 08:20 PM
Shocks lvethelake 1997 - 2003 F150 2 07-30-2016 08:19 AM
shocks for 2008 F150 4X4 ovenrat Brakes, Steering, Suspension, Tires, & Wheels 1 02-01-2016 02:16 PM
Shock question.... mr.dux 1997 - 2003 F150 2 03-03-2006 11:39 PM
Tags
06, 08, 4x4, expectancy, f150, f250, f350, factory, ford, life, lifespan, shocks, span, stock, truck
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
