Go Back   Ford Truck Enthusiasts Forums > Misc. > Alternative Fuels, Hybrids & Mileage
Sign in using an external account
Register Forgot Password?
Register - Join us, its Free! Albums FAQ Members Tech Guides Search Today's Posts Mark Forums Read VendorsUsed CarsGarage
Welcome to Ford Truck Enthusiasts Forums
  #1 (permalink)
Old 03-02-2008, 08:55 PM
SuperSnake's Avatar
SuperSnake SuperSnake is offline
Garage is empty, add now
SuperSnake is a splendid one to beholdSuperSnake is a splendid one to beholdSuperSnake is a splendid one to beholdSuperSnake is a splendid one to beholdSuperSnake is a splendid one to beholdSuperSnake is a splendid one to beholdSuperSnake is a splendid one to beholdSuperSnake is a splendid one to behold
Gas Saver? Welder& cutter?
I was sent this link by a friend.
http://carpoweredwater.blogspot.com/
  #2 (permalink)
Old 03-02-2008, 11:26 PM
aurgathor aurgathor is offline
aurgathor is gaining momentum as a positive member of FTE.
Tell him to fill up with it.
Not sure what's in that link, but I know it's not even worth to open it. Here's one similar thread: http://www.ford-trucks.com/forums/49...r-as-fuel.html
  #3 (permalink)
Old 03-08-2008, 03:57 PM
blue beast's Avatar
blue beast blue beast is offline
blue beast is gaining momentum as a positive member of FTE.blue beast is gaining momentum as a positive member of FTE.
H2O powering anything but a hydroelectric generation plant that then charges an
electric car is the only way we will be driving "powered with water" But H2O2 is
a possibility if it wasn't so dangerous at the purity needed to be used as a fuel!!
Yes hydrogen peroxide it is a viable alternative But the majority of the H202 that
is produced is used for spaceflight and that isn't going to change anytime soon.
The H2O2 you have in you medicine cabinet is only 3% and you can see it's reactivity
with contact on just skin. If a higher percentage was used and with a cataqlyst we
could have turbines powered by it by just the liberation of the components, then
take the O2 and the hydrogen and combine that with some fuel (alcohol, kerosene
just about anything) and use it to fuel a internal com bustion engine in a Hybrid
type vehicle basically the turbine spinning a generator to charge up some capacitors
and battery banks then power a electric motor transaxle with the engine as a backup.
__________________
86 fs bronco 302 auto 33x12.50 at rusty but trusty!
91 ford probe lx mtx The mighty vulcan 3.0
Before posting fuel related problems Run a couple of bottles of dedicated gas line dryer through IT!!
Tags
f150, gas, parts, saver, truck
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is On
Trackbacks are On
Pingbacks are On
Refbacks are On
Forum Jump
Powered by vBulletin® Version 3.7.5
Copyright ©2000 - 2013, Jelsoft Enterprises Ltd.
SEO by vBSEO 3.5.2 ©2010, Crawlability, Inc.
vbulletin Admin Backup
