Go Back   Ford Truck Enthusiasts Forums > Older, Classic and Antique Trucks > 1980 - 1986 F100, F150 And Larger F-Series Trucks
Register - Join us, its Free! FAQ Members List Timeslips Calendar Mark Forums Read
Is F-150 Still King?
LinkBack Thread Tools
  #1 (permalink)
Old 03-02-2008, 08:42 PM
somzat is starting off with a positive reputation.
stalls after thirty min. wont start back
I have a 1980 pickup with a 302m. The engine stalls after 20 or 30 mins And wont start back for hours. I put a new inline filter on and an ignition module. Fuel filter? Any theories?
Sponsored Links
To remove this ad, register today!
  #2 (permalink)
Old 03-02-2008, 09:28 PM
Franklin2's Avatar
Franklin2 has a great reputation on FTE.Franklin2 has a great reputation on FTE.Franklin2 has a great reputation on FTE.Franklin2 has a great reputation on FTE.Franklin2 has a great reputation on FTE.
Get it to the point it will not run, and then take the aircleaner off and while looking down the carb throat, push back on the throttle. Gas should pour into the engine. If it doesn't, you have a fuel problem and I would concentrate in that area.
If you have fuel, then take a sparkplug wire off and stick a screwdriver up in the end of the wire and hold the metal part of the screwdriver close to the engine block while someone cranks the engine. You should see a spark jump from the screwdriver to the engine block. If not, you have a ignition problem, and the first thing I would try is replacing the ignition module.
__________________
Dave F
1989 F250 XLT Diesel
  #3 (permalink)
Old 03-02-2008, 09:59 PM
doug1222556's Avatar
doug1222556 is starting off with a positive reputation.
If you hadn't put a new ignition module on, I'd say that was it. Maybe it is anyway. The only other thing I can think of is the coil overheating and crapping out, but I'm really reaching here as I've never heard of it or experienced it before, but it makes sense logically.
  #4 (permalink)
Old 03-02-2008, 10:14 PM
Piffery1 is gaining momentum as a positive member of FTE.
The pickup coil in the distributor can also cause that symptom if you get no spark when hot.
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is On
Trackbacks are On
Pingbacks are On
Refbacks are On
Powered by: vBulletin | Copyright ©2000 - 2008, Jelsoft Enterprises Ltd.
Ford-Trucks.com and Internet Brands, Inc. are not affiliated with the Ford Motor Company.
