EGR tube problems - Ford Truck Enthusiasts Forums
EGR tube problems
Old 03-02-2008, 08:41 PM
90Fordgirl 90Fordgirl is offline
90Fordgirl is starting off with a positive reputation.
Cool EGR tube problems
I need help finding a solution to a cracked EGR tube. I have been looking online but I can't find one and the one at the dealer is expensive. Does anyone have any sugesstions. By the way I don't know if it matters but I have a 1990 extended cab with a 5.8 liter engine.
Old 03-02-2008, 08:59 PM
str8racing str8racing is offline
str8racing is starting off with a positive reputation.
I need one for a 90 f350 7.5 and can't find one.
Old 03-02-2008, 09:14 PM
antivtec antivtec is offline
antivtec is starting off with a positive reputation.
junk yard?
Old 03-02-2008, 09:42 PM
Is there any way to bypass it without making the engine run bad
Old 03-02-2008, 09:53 PM
Quote:
yes you can get rid of it and then block it off at the exhaust manifold and the intake where it bolts to. did this to my 89 mustang before i put my carbed motor in it, and my 92 f150 already had it done. both ran fine without it.
Old 03-02-2008, 10:01 PM
BlueOval460 BlueOval460 is offline
BlueOval460 is starting off with a positive reputation.
i took a JIC hydraulic fitting cap (i dont remember what size though maybe a 10 or 12) and screwed it onto the flared fitting (the one that is threaded into the exhaust manifold) that the tube's compression fitting screws on to, and i took the egr valve off and made up a sheet metal cover for it, it throws a code but you can get an egr eliminator chip for like 25 bucks on ebay, it plugs into the harness and tells the computer the egr is working properly, this was on my explorer but it should be the same
Old 03-02-2008, 11:45 PM
lmd91343's Avatar
lmd91343 lmd91343 is offline
lmd91343 is gaining momentum as a positive member of FTE.
Try Autozone.com. They don't list it on their website, but I bought one there about 10 days ago in person. They can look it up on their internal parts system. It cost me $39.99 plus tax. I replaced it as PM while I had my upper manifold off. It takes a 24mm wrench. I believe it was made by GP Sorensen.
I'll pull the box out of the recycle bin in the morning and get the stock number for you. We have people who spend the night going through the recycle bins here, so it may have "disappeared" along with the aluminum cans and other cardboard.
Old 03-03-2008, 01:49 AM
muddyford911's Avatar
muddyford911 muddyford911 is offline
muddyford911 is starting off with a positive reputation.
i know people at ford and i STILL paid like $90 for one. i gotget the list price. i also paid $97 for the EGR valve and they wanted $197. i'd try the junk yard. ebay MIGHT have one too. i dk of anyone that makes an aftermarket EGR tube for these trucks. i cracnked mine trying to clean my EGR valve which turned out to be bad anyways....i looked everywhere for one.
Old 08-31-2009, 03:23 PM
352F100 352F100 is offline
352F100 is starting off with a positive reputation.
Dorman makes OEM replacement EGR tubes. Also called EGR Line. Available for $50 at autopartswarehouse.com or on special order from your local auto parts store.
Old 08-31-2009, 06:50 PM
alxsnmr alxsnmr is offline
alxsnmr is gaining momentum as a positive member of FTE.
Rock auto (www.rockauto.com) listes the egr tube as "EGR Line" for the 5.8:
DORMAN Part # 598101 {OE Solutions #F0TZ9D477A} for 34 bucks
for the 7.5:
DORMAN Part # 598108 {OE Solutions #F7TZ9D477CA} for 23 bucks
Look up your vehicle then under emission then EGR Line.
Old 03-27-2010, 10:55 PM
bigcrunch bigcrunch is offline
bigcrunch is starting off with a positive reputation.
Quote:
I have a 93 7.5 I may want to plug off the EGR, any power or driveability issues?
Old 03-28-2010, 02:54 AM
1994 F250: 351, C6 1994 F250: 351, C6 is offline
1994 F250: 351, C6 is gaining momentum as a positive member of FTE.
Eliminating the EGR is not a good idea, it is asking for problems. I had my EGR tube crack about a year and a half ago, and I fixed it for about $5. Go to an auto parts store and get a tube of QuikSteel, it is a putty that mix by kneeding it in your hand and it sets up really hard. Way less messy and better than JB Weld. Use a lot of it, - used a whole 2 oz tube on my EGR pipe. It looks like hell, but you don't see it and it has not leaked for the last year and a half.
Old 07-29-2010, 03:30 PM
Beastlyforddude's Avatar
Beastlyforddude Beastlyforddude is offline
Beastlyforddude is starting off with a positive reputation.
its not to hard to make the pipe, elbow grease
Old 07-29-2010, 09:22 PM
BCHauler's Avatar
BCHauler BCHauler is offline
BCHauler has a good reputation on FTE.BCHauler has a good reputation on FTE.
I bought mine off of ebay. Check around, they are available. And I also wouldn't recommend removing the egr setup.
Old 07-29-2010, 10:29 PM
ac700wildcat ac700wildcat is offline
ac700wildcat is starting off with a positive reputation.
I also checked RockAuto for you. I entered a 1990 f150 supercab with a 5.8 motor and it comes up as $28.79 for the egr line and its the same exact part number as posted earlier.......weird.
Part Number Help - EGR Tube w/DPFE 1996 F-150 4.9 Yaga1973 1987 - 1996 F150 & Larger F-Series Trucks 15 08-15-2016 02:18 PM
Any tricks for separating EGR tube from exhaust manifold? dbbldz 1968-2013 Full Size Vans 0 04-03-2016 03:14 PM
egr for headers alabamaredneckfla Ranger & B-Series 4 07-30-2015 06:11 AM
Can't locate a EGR tube for a 1990, help please. abranz Ford Inline Six, 200, 250, 4.9L / 300 2 11-14-2011 09:03 PM
'88 460 EFI egr valve? AMSContr Big Block V8 - 385 Series (6.1/370, 7.0/429, 7.5/460) 3 07-25-2007 06:54 PM
Tags
2002, 50, 58, bypass, ebay, egr, exhaust, explorer, f150, ford, liter, parts, problems, system, tube, tubes, valve
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
