Needed:F-250 Dana 50 TTB suspension diagram
Old 06-02-2015, 12:38 PM
94windsor's Avatar
94windsor
94windsor is offline
Can't find anything but F-150 stuff on the google. Looking for a parts diagram that specs out tie rod ends, sleeves, joints, etc.
Regards,
Old 06-02-2015, 02:36 PM
jaagen's Avatar
jaagen
jaagen is offline
Can you be a little more specific. Do you need torque values or measurements? My Haynes or chilton does give a very good picture of said parts.
Old 06-03-2015, 08:42 AM
94windsor's Avatar
94windsor
Looking for proper nomenclature for front end parts such as the tie rods, sleeves, etc. Looking at rockauto is pretty cryptic for these trucks. My truck has a lot of rust from sitting around. Pulled the wheel to start a brake line replacement when I noticed that the castle nuts on the tie rods are turning to powder. I would like to replace the entire tie rod set up on both sides, new calipers, Rubber lines - then I can have it towed to a shop to figure out why it won't start. No one would take it with out brakes. (obviously!)
Old 06-03-2015, 03:13 PM
jaagen's Avatar
jaagen
jaagen is offline
Is this what you need. Think you can zoom in
Old 06-04-2015, 07:49 AM
94windsor's Avatar
94windsor
YES! This is awesome.
Beers to you Sir!
Thanks
Old 06-04-2015, 09:15 AM
joegeds's Avatar
joegeds
joegeds is offline
These might help as well. If you need more from the 96 service manual, let me know.
File Type: pdf
72CC428
02-09-2017 03:42 PM
Lex2002
24
04-15-2016 10:20 PM
Bobbys Big Red Rig
1999 to 2016 Super Duty
06-12-2013 12:41 PM
bgriffin09
13
04-27-2013 06:05 AM
northernmoose
Offroad & 4x4
05-29-2009 06:59 PM
Quick Reply: Needed:F-250 Dana 50 TTB suspension diagram
