EGR tube problems
Old 07-30-2010, 07:42 AM
larrylass's Avatar
larrylass
larrylass is offline
Originally Posted by str8racing
I need one for a 90 f350 7.5 and can't find one.
Go to Lowes and in the plumbing section just start looking for flexible gas line and the fittings. It takes a while but it can be done,because i did it. It was a total PITA to do though. I believe i had to buy some copper tubing that fit the inside diameter of the flex hose -cut off a small piece and flare the end and hose clamp the flex line to it.
BigLar
Old 03-03-2013, 06:24 PM
Benztechnc's Avatar
Benztechnc
Benztechnc is offline
old thread revisited.
I know this is an old thread, and I thought about starting a new one. But there is nothing like having all the information in one place.
So my questions, is the Dorman Part #598108 good for an 87 w\460 -C6 -CC-4x4 (I gotta get a shorter truck!). Just found mine was broke after tearing off the heads. I've been chasing an exhaust leak for years, even ordered the 'special' Hedman Headers gasket for the headers. Rock Auto do not list an EGR tube for my vehicle. But that one is listed for both 250's and 350's for 1990.
Old 03-03-2013, 06:33 PM
Benztechnc's Avatar
Benztechnc
Old 05-18-2013, 07:27 AM
Benztechnc's Avatar
Benztechnc
Update. It did work. Just an FYI.
Old 05-18-2013, 11:01 PM
*2fords*'s Avatar
*2fords*
*2fords* is offline
What are the symptoms of a cracked egr tube?
I replaced the 3 major componants of the ger system, as it was throwing a bad egr code.
I did find my tube broken at the joint where the flex part meets the solid part of the tube. I thought I had fixed it with a piece of copper tubing, hose clamps and high heat fire place caulking. But now i wonder if I still have a bad leak causing my truck to run like severe crap.
If I remember right, the egr tube disappears under the plenim. Do I have to remove the plenim in order to replace or fix the tube better?
Old 05-19-2013, 09:38 AM
bootmaker's Avatar
bootmaker
bootmaker is offline
I see them in the salvage yards all the time. eBay is also a good source.
Old 07-20-2014, 09:25 PM
A. stand's Avatar
A. stand
A. stand is offline
Originally Posted by 90Fordgirl
I need help finding a solution to a cracked EGR tube. I have been looking online but I can't find one and the one at the dealer is expensive. Does anyone have any sugesstions. By the way I don't know if it matters but I have a 1990 extended cab with a 5.8 liter engine.
Did you get it deleted and how did it work
Old 07-20-2014, 10:58 PM
Truck Guy99's Avatar
Truck Guy99
Truck Guy99 is offline
Summit has them
http://www.summitracing.com/parts/rn...rd/model/f-250
I blocked the egr on my sig truck and have no issues.
Old 06-04-2015, 12:13 PM
Dentonry's Avatar
Dentonry
Dentonry is offline
Originally Posted by BlueOval460
i took a JIC hydraulic fitting cap (i dont remember what size though maybe a 10 or 12) and screwed it onto the flared fitting (the one that is threaded into the exhaust manifold) that the tube's compression fitting screws on to, and i took the egr valve off and made up a sheet metal cover for it, it throws a code but you can get an egr eliminator chip for like 25 bucks on ebay, it plugs into the harness and tells the computer the egr is working properly, this was on my explorer but it should be the same
I just spent about $300 for new tube and valve and still not working. I hate to override the code but I need to smog my truck so I bought the eliminator you spoke of. Where exactly does that it plug into the wiring harness?
Yaga1973
18
10-19-2019 08:42 PM
Randy Green
03-12-2017 09:29 PM
jmccracken1214
02-19-2017 02:10 PM
izphelps
09-14-2010 08:49 AM
LimeyZ
05-15-2005 06:49 PM
Quick Reply: EGR tube problems
