Go Back   Ford Truck Enthusiasts Forums > Older, Classic and Antique Trucks > 1980 - 1986 F100, F150 And Larger F-Series Trucks
Register - Join us, its Free! FAQ Members List Timeslips Calendar Mark Forums Read
Is F-150 Still King?
LinkBack Thread Tools
  #1 (permalink)
Old 03-02-2008, 08:09 PM
BlueOvalBud is starting off with a positive reputation.
F-250 Rear End
Hi guys,
looking at a '84 f-250 right now to pull the rear end out of. It's NOT a Ford/Sterling because the oil Fill Plug is on the inspection cover, So that would make it a Dana right? This truck is also an F-250, so it would probably be a Dana 60 correct? I did notice that there as a "70" stamped on the casting, on the pinion side, to the right and towards the top of the axle. So my question is, what is it? on the Vin plate, the axle code is G3. I assume it's a dana because the fords all ran Dana's until '85 when the sterling came into production. So, can you guys help me figure out what this is? Thank you
P.S. the vin number is 2FTHF2511FCA50079 just in case that helps, i already decoded it, doesn't help on the identifying the rear end
Sponsored Links
To remove this ad, register today!
  #2 (permalink)
Old 03-02-2008, 09:33 PM
Franklin2's Avatar
Franklin2 has a great reputation on FTE.Franklin2 has a great reputation on FTE.Franklin2 has a great reputation on FTE.Franklin2 has a great reputation on FTE.Franklin2 has a great reputation on FTE.
G3 is a 3.54 to 1 Dana rear. Make sure it has the axle stubs sticking out beyond each rear rim. That will signify it's a full floating heavy duty axle. Otherwise it would be a lighter duty semi-floating axle.
__________________
Dave F
1989 F250 XLT Diesel
  #3 (permalink)
Old 03-02-2008, 09:49 PM
ok thank you,
the axle stubs ended up being flush to the rear rims, but i guess it can't be too bad
  #4 (permalink)
Old 03-02-2008, 09:53 PM
Franklin2's Avatar
It's a rearend for a light duty f250. I believe the center part is the same, but it doesn't have the double wheel bearings out at the wheels.
__________________
Dave F
  #5 (permalink)
Old 03-02-2008, 10:02 PM
oh ok, thank you for your help, it's greatly appreciated
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is On
Trackbacks are On
Pingbacks are On
Refbacks are On
Powered by: vBulletin | Copyright ©2000 - 2008, Jelsoft Enterprises Ltd.
Ford-Trucks.com and Internet Brands, Inc. are not affiliated with the Ford Motor Company.
