Go Back   Ford Truck Enthusiasts Forums > Performance, Engines and Troubleshooting > Ford V6 > 3.8 & 4.2L V6
Register - Join us, its Free! FAQ Members List Timeslips Calendar Mark Forums Read
Is F-150 Still King?
LinkBack Thread Tools
  #1 (permalink)
Old 03-02-2008, 07:52 PM
atvchick is starting off with a positive reputation.
3.8 oil pressure
I have a 1995 a mustang with a 3.8 v6 it has about 14000 miles.in the last year or so the oil pressure has dropped it used to run on the L ( normal) now it runs around the N the oil has always been changed every 3000 miles.also were is the oil pump located i it in the oil pan or is it in the timing cover.thanks
Sponsored Links
To remove this ad, register today!
  #2 (permalink)
Old 03-05-2008, 11:12 PM
floydguy is starting off with a positive reputation.
the 3.8 oil pump is in the timming cover, the gears are in the cover behind the oil filter adapter, the gears also wear the inside of the aluminum cover, causing a drop in oil pressure, that was the case on my 87 t-bird.
  #3 (permalink)
Old 03-06-2008, 08:22 AM
I had to replace the timing cover a few years back so what could be causing my low oil pressure is the screen in the pan maybe it is getting stoped up.thanks
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is On
Trackbacks are On
Pingbacks are On
Refbacks are On
Powered by: vBulletin | Copyright ©2000 - 2008, Jelsoft Enterprises Ltd.
Ford-Trucks.com and Internet Brands, Inc. are not affiliated with the Ford Motor Company.
