00 f-350 Rear Axle Code? - Ford Truck Enthusiasts Forums
1999 to 2016 Super Duty 1999 to 2016 Ford F250, F350, F450 and F550 Super Duty with diesel V8 and gas V8 and V10 engines
Old 03-02-2008, 11:10 AM
quality1construction quality1construction is offline
quality1construction is starting off with a positive reputation.
Smile 00 f-350 Rear Axle Code?
I am trying to figure out what gears I have in my 00 F350, its a 7.3L, 6SPD.4X4. Crewcab, Longbed, 4x4 Offroad. I looked on the label on the door pillar but theres no code there under axle? How do I figure this out? Thanks for your help. Built date is 9-99 if that helps.
Old 03-02-2008, 11:25 AM
rotun's Avatar
rotun rotun is offline
Reads ***** rules!
rotun has a good reputation on FTE.rotun has a good reputation on FTE.
Ford usually has a metal tag hangin off one of the diff cover bolts. It will have a series of numbers and letters on it something like this.. 9 3L75 that would be a 9" rear with 3.75 ratio and locking diff if theres no "L" between the numbers it has an open diff.
Old 03-02-2008, 12:54 PM
Unfortunately there is no tag on the diff anywhere. I am trying to find out what the ratio is. Thanks
Old 03-02-2008, 12:59 PM
rotun's Avatar
Reads ***** rules!
They also stamp the code on the axle tube itself, tags can be torn off, fall off, etc. You can PM your vin # and I can find out what it had from the factory for you.
Old 03-02-2008, 01:16 PM
Smile
Quote:
Here is the Vin # 1FTSW31F6YEA55613, I appreciate the help.
Old 03-02-2008, 01:30 PM
rotun's Avatar
Reads ***** rules!
<TABLE width=740><TBODY><TR><TD>VIN:</TD><TD noWrap>1FTSW31F6YEA55613</TD><TD>Veh Line:</TD><TD noWrap>T/F7 - F250HD/350/450/550 [99-08]</TD><TD noWrap>Eng Serial No:</TD><TD>1124784F</TD></TR><TR><TD noWrap>Model Year:</TD><TD>2000</TD><TD noWrap>Market Derived:</TD><TD noWrap>F - FORD</TD><TD>Body Shell:</TD><TD noWrap>*</TD></TR><TR><TD>Veh Type:</TD><TD noWrap>T</TD><TD>Drive Code: <TD noWrap>T/E - 4 WHL L/H PART TIME DRIVE</TD><TD>Engine:</TD><TD noWrap>T/DS - NAVISTAR 7.3L OHV DI TC V8 DSL</TD></TR><TR><TD noWrap>Inv. Dealer:</TD><TD noWrap>*</TD><TD>Body Cab Style:</TD><TD noWrap>T/BC -DOUBLE CAB (CREW CAB)</TD><TD>Transmission:</TD><TD noWrap>T/VF - 6 SPD MAN TRANS Z/F M6HD-C</TD></TR><TR><TD></TD><TD></TD><TD>Version/Series:</TD><TD noWrap>T/CD - 350 SERIES</TD></TR></TBODY></TABLE>
<HR><!--ADD trace serial numbers --><TABLE width=740><TBODY><TR><TD>Trace Eng Serial No:</TD></TR><TR><TD>---------1----------2---------3--------4---------5-----------6----------7---------8</TD></TR><TR><TR><TD>NA</TD></TR></TR><TR><TD>Trace Trans Serial No:</TD></TR><TR><TR><TD>NA</TD></TR></TR></TBODY></TABLE><!-- end -->
<HR><TABLE><TBODY><TR><TD colSpan=4>BUILD INFORMATION:
</TD></TR><TR><TD>Region:</TD><TD>NA - ##########</TD><TD>Plant:</TD><TD>A1 - KENTUCKY TRUCK PLANT BUILD</TD></TR><TR><TD>Country:</TD><TD>USA - ##########</TD><TD>Prod Date:</TD><TD>01-SEP-1999</TD></TR></TBODY></TABLE>
<HR><TABLE><TBODY><TR><TD colSpan=4>SALE INFORMATION:
</TD></TR><TR><TD>Region:</TD><TD>NA - ##########</TD><TD>Selling Dealer:</TD><TD>152042 -*</TD></TR><TR><TD>Country:</TD><TD>USA - ##########</TD><TD>Selling Dlr St/Prov:</TD><TD>TX</TD></TR><TR><TD></TD><TD></TD><TD>Buyer St/Prov:</TD><TD>*</TD></TR><TR><TD></TD></TR></TBODY></TABLE><TABLE><TBODY><TR><TD>Arrival Date:</TD><TD>16-SEP-1999</TD><TD>Red Carpet Lease:</TD><TD>*</TD><TD></TD><TD></TD></TR><TR><TD>Sale Date:</TD><TD>20-SEP-1999</TD><TD>Fleet/Retail/Co. Lease:</TD><TD>R</TD><TD></TD><TD></TD></TR><TR><TD>Warranty Start Date:</TD><TD>20-SEP-1999</TD><TD>Modified Vehicle:</TD><TD>*</TD><TD></TD><TD></TD></TR><TR><TD>Orig Warranty Date:</TD><TD>20-SEP-1999</TD><TD>Reacquired Vehicle:</TD><TD>*</TD><TD>Vehicle Export Flag:</TD><TD>N</TD></TR></TBODY></TABLE>
<HR>
<TABLE><TBODY><TR><TD>VOC/EOC:
</TD></TR><TR><TD>---------1---------2---------3---------4---------5---------6---------7---------8----------9----------</TD></TR><TR><TD>
W31YEA556131723 L 3M1 23H9006 CF EH 6D1Z43 2NSQT 2KX R SM B 52B042 93 Z1 8HS 8 F</PRE>
</TD></TR><TR><TD>
1FTS6 1 H P 618A 9F6TX M</PRE>
</TD></TR></TBODY></TABLE></P><HR><TABLE><TBODY><TR><TD colSpan=4>INSTALLED OPTION INFORMATION:
</TD></TR><TR><TD>Air Conditioning:</TD><TD>T/B - MANUAL AIR CONDITIONER</TD><TD>GVW Code:</TD><TD></TD></TR><TR><TD>Alternator Amp Rating:</TD><TD>8E</TD><TD>GVW Class Code:</TD><TD>S</TD></TR><TR><TD>Audio Disk:</TD><TD>* - [N/A]</TD><TD>Instrumentation:</TD><TD>* - [N/A]</TD></TR><TR><TD>Axle Ratio:</TD><TD>EGAJB - 3.73 FINAL DRIVE RATIO</TD><TD>Mirror(Driver Side):</TD><TD>AQ - DRIVER PADDLE FOLD AWAY MIRROR</TD></TR><TR><TD>Axle Type:</TD><TD>EGJAC - LIMITED SLIP REAR AXLE</TD><TD>Mirror(Psngr Side):</TD><TD>* - [N/A]</TD></TR><TR><TD>Battery Amp Rating:</TD><TD>BA</TD><TD>Paint:</TD><TD>PNYW5 - OXFORD WHITE WB C/C-W/B</TD></TR><TR><TD>Brake Code:</TD><TD>* -[N/A]</TD><TD>Power Antenna:</TD><TD>* - [N/A]</TD></TR><TR><TD>Brake Code(Service):</TD><TD>* -[N/A]</TD><TD>Radio:</TD><TD>BE - ELETR PREM STRO/CSTE/DISC/CLK</TD></TR><TR><TD>Calibration Code:</TD><TD>*</TD><TD>Sound System:</TD><TD>* -[N/A]</TD></TR> <TR><TD>Color(Accent):</TD><TD>* - [N/A]</TD><TD>Suspn Tandem Axle:</TD><TD></TD></TR><TR><TD>Color(Trim):</TD><TD>000HF - MED PARCHMENT</TD><TD>Tire Brand:</TD><TD>* - [N/A]</TD></TR><TR><TD>Delivery Type:</TD><TD>0</TD><TD>Tire Size:</TD><TD>D3JYF - LT265/75R-16E A-S BSW</TD></TR><TR><TD>Driveshaft Code:</TD><TD>*</TD><TD>Traction Control:</TD><TD>* - [N/A]</TD></TR><TR><TD>Front Seat:</TD><TD>T/S - SEATS - INDIVIDUAL 40/20/40</TD><TD>Wheel Base:</TD><TD></TD></TR><TR><TD>Fuel Type:</TD><TD>* -[N/A]</TD></TR></TBODY></TABLE>
Old 03-02-2008, 01:41 PM
Thanks Rotun, You have any idea what the fuel mileage will be on this with the 3.73 axles?
Old 03-02-2008, 02:04 PM
redford's Avatar
redford redford is online now
redford has a superb reputationredford has a superb reputationredford has a superb reputationredford has a superb reputationredford has a superb reputationredford has a superb reputationredford has a superb reputationredford has a superb reputationredford has a superb reputationredford has a superb reputationredford has a superb reputation
If you are light on the throttle and brake you could get 20 MPG.
Old 03-02-2008, 02:06 PM
Mat J Mat J is offline
Mat J is starting off with a positive reputation.
hey rotun do you think you could find the axle codes from my vin too, i tried this sites vin decoder but it didnt have it.
1fthx26g0jka08118
i also looked on my axles but couldnt find it.
Old 03-02-2008, 02:08 PM
Izzy351's Avatar
Izzy351 Izzy351 is offline
Izzy351 has much to be proud ofIzzy351 has much to be proud ofIzzy351 has much to be proud ofIzzy351 has much to be proud ofIzzy351 has much to be proud ofIzzy351 has much to be proud ofIzzy351 has much to be proud ofIzzy351 has much to be proud ofIzzy351 has much to be proud ofIzzy351 has much to be proud of
Quote:
I get 18-19 on the highway if I'm nice with the pedal and keep it below 2000 RPM. You should do better keeping it at 60-65 or so. I get about 15-16 mixed city/highway and mixed driving it hard and nice.
Old 03-02-2008, 02:58 PM
rotun's Avatar
Reads ***** rules!
A 7.3L with 3.73's AND a manual trans.............hard to say as most vehicles with identicle equip. vary in mpg, but you should see at least 17-20. I get 17-18 on my '03 7.3L with auto trans. with a full lumber rack installed and I'm not easy on the pedal.
Old 03-02-2008, 03:05 PM
rotun's Avatar
Reads ***** rules!
Quote:
1fthx26g0jka08118
Well, I tried, can't go any farther back then a build date of July 2000. Check all around the rear axle tubes, there are codes stamped, then you can decipher gears through the codes.
Old 03-02-2008, 03:09 PM
thanks anyway
08'-10' Front Axle upgrade to 99'-04' SD or EX HaydenFryGuy 1999 to 2016 Super Duty 4 01-31-2016 05:52 PM
f100 front and rear axle more 4x4 1961 f100 4x4 Ford Truck Parts for Sale 3 09-29-2015 09:35 PM
Strange Axle code - Help whisler 1980 - 1986 Bullnose F100, F150 & Larger F-Series Trucks 2 10-03-2013 11:37 PM
axle id? help sstasel96f350 1994.5 - 1997 7.3L Power Stroke Diesel 3 09-13-2013 08:39 AM
F350 Super cab 4x4 axle ????? mean351stang 1973 - 1979 F-100 & Larger F-Series Trucks 62 07-10-2013 09:02 AM
Tags
2007, axle, code, codes, f350, frd, gear, rear, vin
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
